Is there any way to disable service flapping alerts
srikanth.kallu
Post by srikanth.kallu »
Is there any way to disable service flapping alerts.
I have disabled them in notification settings, But i still get the service flapping alerts because they are not disabled in CCM.
Now is there any way to disable all the service flapping alerts in CCM other than disable it on each service manually.
CGraham
Re: Is there any way to disable service flapping alerts
Post by CGraham »
Do you mean system wide? You could go to the left side pane Monitoring Info > Process Info and disable Flap Detection.
But for services specifically, if they use a generic service template you could disable it there.
abrist
Red Shirt
Post by abrist »
In XI, you can use the bulk modification tool to change this option (among others) system-wide. It requires the enterprise edition, but you can just start a trial of enterprise to access the feature. Go to --> XI --> Configure --> CCM --> Tools --> Bulk Modifications --> Change a Single Config Option --> Flap detection enabled --> "off" --> save.
srikanth.kallu
Is this path correct ? because i dont see the option bulk modifiaction in Go to --> XI --> Configure --> CCM --> Tools --> Bulk Modifications
Post by slansing »
Do you have Nagios XI Enterprise edition?
srikanth.kallu
What do you mean by enterprise edition,
I have this "Nagios XI 2011R3.3"
Post by slansing »
Okay so you do not have bulk mod's tool, this was added as a part of the Nagios XI 2012 Enterprise edition. So that would be out of the question.
srikanth.kallu
Is Nagios XI different from enterprise edition.
I believe you also have 2013 edition which on is the latest.
And how o i upgrade to it.
Post by slansing »
Nagios XI 2012 1.6 is the newest version, Enterprise edition adds features targeted more towards large installations. To upgrade you can simply download the latest version from our site and run the upgrade script after un-tarring the .tar.gz. To upgrade to enterprise edition you can contact our sales department for a quote at: [email protected]
The latest release is Nagios XI 2012R1.6. You can download it from this page:
http://library.nagios.com/library/produ ... loads/main
Please, read our upgrade instructions here:
http://assets.nagios.com/downloads/nagi ... ctions.pdf
Here's the comparison between the Standard and Enterprise Editions of Nagios XI:
http://www.nagios.com/products/nagiosxi/whatsnew
Hope this helps.
