Web interface lagging/slow/not repsponding
anthony.rabbito
Post by anthony.rabbito »
I've been testing the XI version trial to replace our SolarWinds Orion server. I've also been using the Core version for several years without any issues.
I've been having several issues with response time for the XI installation that monitors 18 devices (servers, switches, firewalls). I've given the VM a substantial amount of resources which are hardly being used and still the web interface stops responding/freezes/loads at a snails pace. Any ideas here? this will need to replace our 1000+node solution if it can handle it. Below is a snapshot of what most pages do.
sreinhardt
-fno-stack-protector
Re: Web interface lagging/slow/not repsponding
Post by sreinhardt »
What browser and version are you using? Also what version of XI is this? This looks similar to IE compatibility mode issues. Depending on the resources given Nagios should have no difficulties with 18 hosts and possibly upwards to 1k, that would also heavily depend on the number of service checks.
Did you try using a different browser? What is the version of Nagios XI that you are using?
anthony.rabbito
Nagios XI 2012R1.4
I've tried Firefox/Aurora/Chrome/IE 8/9/10
19 hosts
226 service checks
8GB RAM
4vCPUs
abrist
Red Shirt
Post by abrist »
Do a running tail on /var/log/httpd/error_log and then try to navigate to one or more of the slow pages. Post the output here in a code wrap:
tail -f /var/log/httpd/error_log
anthony.rabbito
[root@nagiosxi libexec]# tail -f /var/log/httpd/error_log
[Wed Feb 13 14:51:07 2013] [error] [client 192.168.168.28] PHP Notice:  Undefined variable: c in /usr/local/nagiosxi/html/includes/components/latestalerts/latestalerts.inc.php on line 521, referer: http://192.168.168.74/nagiosxi/dashboards/dashboard.php?id=p7bnnj
[Wed Feb 13 14:52:37 2013] [error] [client 192.168.168.28] PHP Warning:  arsort() expects parameter 1 to be array, null given in /usr/local/nagiosxi/html/includes/components/latestalerts/latestalerts.inc.php on line 517, referer: http://192.168.168.74/nagiosxi/dashboards/dashboard.php?id=p7bnnj
[Wed Feb 13 14:52:37 2013] [error] [client 192.168.168.28] PHP Warning:  Invalid argument supplied for foreach() in /usr/local/nagiosxi/html/includes/components/latestalerts/latestalerts.inc.php on line 518, referer: http://192.168.168.74/nagiosxi/dashboards/dashboard.php?id=p7bnnj
[Wed Feb 13 14:52:37 2013] [error] [client 192.168.168.28] PHP Notice:  Undefined variable: c in /usr/local/nagiosxi/html/includes/components/latestalerts/latestalerts.inc.php on line 521, referer: http://192.168.168.74/nagiosxi/dashboards/dashboard.php?id=p7bnnj
[Wed Feb 13 14:54:07 2013] [error] [client 192.168.168.28] PHP Warning:  arsort() expects parameter 1 to be array, null given in /usr/local/nagiosxi/html/includes/components/latestalerts/latestalerts.inc.php on line 517, referer: http://192.168.168.74/nagiosxi/dashboards/dashboard.php?id=p7bnnj
[Wed Feb 13 14:54:07 2013] [error] [client 192.168.168.28] PHP Warning:  Invalid argument supplied for foreach() in /usr/local/nagiosxi/html/includes/components/latestalerts/latestalerts.inc.php on line 518, referer: http://192.168.168.74/nagiosxi/dashboards/dashboard.php?id=p7bnnj
[Wed Feb 13 14:54:07 2013] [error] [client 192.168.168.28] PHP Notice:  Undefined variable: c in /usr/local/nagiosxi/html/includes/components/latestalerts/latestalerts.inc.php on line 521, referer: http://192.168.168.74/nagiosxi/dashboards/dashboard.php?id=p7bnnj
[Wed Feb 13 14:55:37 2013] [error] [client 192.168.168.28] PHP Warning:  arsort() expects parameter 1 to be array, null given in /usr/local/nagiosxi/html/includes/components/latestalerts/latestalerts.inc.php on line 517, referer: http://192.168.168.74/nagiosxi/dashboards/dashboard.php?id=p7bnnj
[Wed Feb 13 14:55:37 2013] [error] [client 192.168.168.28] PHP Warning:  Invalid argument supplied for foreach() in /usr/local/nagiosxi/html/includes/components/latestalerts/latestalerts.inc.php on line 518, referer: http://192.168.168.74/nagiosxi/dashboards/dashboard.php?id=p7bnnj
[Wed Feb 13 14:55:37 2013] [error] [client 192.168.168.28] PHP Notice:  Undefined variable: c in /usr/local/nagiosxi/html/includes/components/latestalerts/latestalerts.inc.php on line 521, referer: http://192.168.168.74/nagiosxi/dashboards/dashboard.php?id=p7bnnj
[Wed Feb 13 14:57:07 2013] [error] [client 192.168.168.28] PHP Warning:  arsort() expects parameter 1 to be array, null given in /usr/local/nagiosxi/html/includes/components/latestalerts/latestalerts.inc.php on line 517, referer: http://192.168.168.74/nagiosxi/dashboards/dashboard.php?id=p7bnnj
[Wed Feb 13 14:57:07 2013] [error] [client 192.168.168.28] PHP Warning:  Invalid argument supplied for foreach() in /usr/local/nagiosxi/html/includes/components/latestalerts/latestalerts.inc.php on line 518, referer: http://192.168.168.74/nagiosxi/dashboards/dashboard.php?id=p7bnnj
[Wed Feb 13 14:57:07 2013] [error] [client 192.168.168.28] PHP Notice:  Undefined variable: c in /usr/local/nagiosxi/html/includes/components/latestalerts/latestalerts.inc.php on line 521, referer: http://192.168.168.74/nagiosxi/dashboards/dashboard.php?id=p7bnnj
abrist
Red Shirt
Post by abrist »
You can verify the following directive in your /etc/php.ini file:
display_errors=off
anthony.rabbito
abrist
Red Shirt
Post by abrist »
I noticed that in this thread: http://support.nagios.com/forum/viewtopic.php?t=9117 you have done some customizing of the dashboards. These php errors you are experiencing, are they on one of the XI boxes that you have changed the dashboard code? I ask because most of your php errors are in reference to this referrer: http://192.168.168.74/nagiosxi/dashboar ... ?id=p7bnnj
Can you go to: "Admin->System Status" and post a screenshot of this page?
