Grouping
MPIvan
Grouping
Post by MPIvan »
Hi all,
I have read nagios documentation and i get the point of the grouping hosts and other but i need a little help. I would like to make a template and group of hosts and services, for example i would like to have 10 PC-servers to have (i dont know) 5 services like UpTime, CPU, Bandwith, SSH for example and HTTP. Also i would like to do this on Routers, i have 50 routers and to have them in one group and 10 same services to get all of them like Port UPTIME ....
And another problem i can think of this shame is the community string/passwords ... because i use different password and community string on almost all machines.
Any suggestions ?
abrist
Red Shirt
Re: Grouping
Post by abrist »
You can do this a number of ways. The easiest, most direct way, would be to use hostgroups. Create a hostgroup, then create services and add them to the hostgroup. Then add whatever hosts that should have those service checks to the hostgroup. Rinse and repeat for each set of services.
You could also do this through templates. Create a set of services and add them to a servicegroup. Then create a service template and add the servicegroup to it. Then create a hostgroup and add that to the template. Then add hosts to the host group and they will all inherit the checks from the template.
MPIvan
Re: Grouping
Post by MPIvan »
Hi abrist, and tnx for reply ...
that's good idea, ill try some things.. now im trying to work with different community string on each host, and i need help here. For example: i have create in template like this...
define hostgroup{
name group1
use generic-host
members PC1,PC2,PC3
and
define servicegroup{
name servicegroup1
members PC1,Uptime,PC2,Uptime,PC3,Uptime
and now im wondering is there a way to put different community string/password for eche PC and combine with macro to passed for each PC ?
MPIvan
Re: Grouping
Post by MPIvan »
Well i gees i wont need explanation i found the solution ... and here it is....
i made in template.cfg file my definition about host ...
define host {
name     def-host1
use         generic-host
check_period            24x7            ; By default, Windows servers are monitored round the clock
        check_interval          5               ; Actively check the server every 5 minutes
        retry_interval          3               ; Schedule host check retries at 1 minute intervals - 1
        max_check_attempts      10              ; Check each server 10 times (max)
        check_command           check-host-alive        ; Default command to check if servers are "alive"
        notification_period     24x7            ; Send notification out at any time - day or night
        notification_interval   30              ; Resend notifications every 30 minutes
        notification_options    d,r             ; Only send notifications for specific host states
        contact_groups          admins          ; Notifications get sent to the admins by default
        hostgroups              windows-for-def-host1 ; Host groups that Windows servers should be a member of
        register                0
then in the windows.cfg file i made hostgroup and define the hosts
use      def-host1
host_name  PC1
alias            win 8
address       10.10.10.10
_SNMPCOMMUNITY    Test1
define hostgroup{
hostgroup_name    windows-for-def-host1
alias                       windows PC's
members              PC1,PC2,PC3 ; i think it can do without members ...
and the services
use            generic-service
service_description     Uptime
check_command           check_nt!UPTIME
and in the commands.cfg
command_name check_nt
command_line $USER1$/check_nt -H $HOSTADDRESS$ -p 1354 -s $_HOSTSNM$
so thats it ... now im trying to group services so if you have any sugestions pls shear ....
abrist
Red Shirt
Re: Grouping
Post by abrist »
You can group services by hostgroups or by servicegroups attached to templates.
MPIvan
Re: Grouping
Post by MPIvan »
That is my next think. But what can i do with the service like ifOperStatus.0 - for interface fa 0/0 and ifOperStatus.1 for interface 0/1 etc.... how can i solve this repeating ?
abrist
Red Shirt
Re: Grouping
Post by abrist »
MPIvan wrote:That is my next think. But what can i do with the service like ifOperStatus.0 - for interface fa 0/0 and ifOperStatus.1 for interface 0/1 etc.... how can i solve this repeating ?
You really cannot solve it, as they are technically different service checks. If you have a mib/oid for the overall status of the switch you could, but your switch most likely does not have the option.
MPIvan
Re: Grouping
Post by MPIvan »
I did as grouphost .. i have read somewhere that you can split with a " , " in old versions of nagios here and in some other google search results but nothing work or im doing something wrong ...
sreinhardt
-fno-stack-protector
Re: Grouping
Post by sreinhardt »
Sorry that link does not work, seems to be a paid google book. Could you provide another similar link?
MPIvan
Re: Grouping
Post by MPIvan »
I cannot find another link for that book but here is how in the example is written:
check_snmp -H 10.0.0.4 -C public -o IF_MIB::ifOperStatus.1,IF-MIB::ifOperStatus.2
This book is Pro Nagios 2.0 and somewhere in google search i have found similar solution, i cannot find that link but if i remember good it was something like ifOperStatus.1,2,3 something like this or similar
