[Solved] Always map as guest
StreamThreader
Post by StreamThreader »
Hello piople!
Nagios map my user as guest
Apache auth my user OK.
I comment string: (# default_user_name=) in file "cgi.cfg", if i log int, nagios show:
Tactical Monitoring Overview
Last Updated: Thu Feb 14 11:36:02 EET 2013
Updated every 45 seconds
Nagios® Core™ 3.4.3 - http://www.nagios.org
Logged in as ?
What is (Logged in as ?), but must be (Logged in as admin or someone else)
OS: FreeBSD 7.4 (i386)
Apache: 2.2.23
FastCGI: fcgi-devkit-2.4.0
If need additional information or log files, i posted it here.
Last edited by StreamThreader on Fri Feb 15, 2013 10:47 am, edited 2 times in total.
abrist
Red Shirt
Re: Always map as guest
Post by abrist »
Have you set up a proper .htpasswd file and added a user to it? See the following document:
http://nagios.sourceforge.net/docs/3_0/cgiauth.html
StreamThreader
I install new FreeBSD 9.1 under virtualbox, and problem again.
My packages:
[list]apache22-2.2.23_4
apr-1.4.6.1.4.1_3
autoconf-2.69
autoconf-wrapper-20101119
automake-1.12.6
automake-wrapper-20101119
bash-4.2.42
bigreqsproto-1.1.1
bison-2.5.1,1
cmake-2.8.9
cmake-modules-2.8.9
db42-4.2.52_5
expat-2.0.1_2
fontconfig-2.9.0,1
fping-3.4
freetype2-2.4.11
gamin-0.1.10_4
gd-2.0.35_8,1
gdbm-1.9.1
gettext-0.18.1.1
gio-fam-backend-2.28.8_1
glib-2.28.8_5
gmake-3.82_1
help2man-1.41.1
inputproto-2.0.2
jpeg-8_4
kbproto-1.0.5
libICE-1.0.7,1
libSM-1.2.0,1
libX11-1.4.4,1
libXau-1.0.6
libXaw-1.0.9,2
libXdmcp-1.1.0
libXext-1.3.0_1,1
libXmu-1.1.0,1
libXp-1.0.1,1
libXpm-3.5.9
libXt-1.1.1,1
libcheck-0.9.9
libevent2-2.0.21
libgcrypt-1.5.0_1
libgpg-error-1.10
libiconv-1.14
libltdl-2.4.2
libpthread-stubs-0.3_3
libslang2-2.2.4_4
libtool-2.4.2
libxcb-1.7
libxml2-2.7.8_5
libxslt-1.1.28
m4-1.4.16_1,1
mc-4.8.1.7
mysql-client-5.5.30
nagios-3.4.3_1
nagios-plugins-1.4.16,1
net-snmp-5.7.2_2
p5-Crypt-CBC-2.32
p5-Crypt-DES-2.05
p5-Digest-HMAC-1.03
p5-Digest-SHA1-2.13
p5-Locale-gettext-1.05_3
p5-Net-SNMP-6.0.1
pcre-8.32
perl-5.14.2_2
php53-5.3.21
php53-bz2-5.3.21
php53-ctype-5.3.21
php53-dom-5.3.21
php53-exif-5.3.21
php53-extensions-1.6
php53-filter-5.3.21
php53-ftp-5.3.21
php53-gd-5.3.21
php53-hash-5.3.21
php53-iconv-5.3.21
php53-json-5.3.21
php53-mysql-5.3.21
php53-pdo-5.3.21
php53-pdo_sqlite-5.3.21
php53-phar-5.3.21
php53-posix-5.3.21
php53-session-5.3.21
php53-simplexml-5.3.21
php53-sqlite-5.3.21
php53-sqlite3-5.3.21
php53-tokenizer-5.3.21
php53-xml-5.3.21
php53-xmlreader-5.3.21
php53-xmlwriter-5.3.21
pkgconf-0.8.9
png-1.5.14
postgresql-client-9.0.12
printproto-1.0.5
py27-setuptools-0.6c11_3
python27-2.7.3_6
sqlite3-3.7.14.1
t1lib-5.1.2_2,1
tmux-1.7_1
xcb-proto-1.7.1
xcmiscproto-1.2.1
xextproto-7.2.0
xf86bigfontproto-1.2.0
xorg-macros-1.16.1
xproto-7.0.22
xtrans-1.2.6
[/list]
StreamThreader
Solved!
Modify /usr/local/etc/apache22/Includes/nagios.conf
AllowOverride AuthConfig
AuthType Basic
AuthName "Nagios Access"
#    Deny from all
Allow from all
And Nagios work!
Tnhanks for supporting me.
I inattentive.
This problem in apache, apache not require auth user.
If turn on require apache for login and password, all work!
