Template: Check interval doesn't work ???
morabanc
Post by morabanc »
How can I create a template that execute a service check 3 hours by 3 hours ??
I create a "service template" and on the "Check settings" tab I modify the "Check interval" value at 180 minutes (3 hours) but in the service check "status detail" I see something like this
Last Check: 14/02/2013 17:16:22
Next Check: 14/02/2013 17:23:05
Thanks !!!! :D
Re: Template: Check interval doesn't work ???
Are you trying to use a custom template or you are modifying the check settings under "Service Management". All settings on the service level will override the template. What is the "Retry interval" value for this check under "Service Management"?
CCM->Services->...->Modify->Check Settings tab
morabanc
Post by morabanc »
Hi !!!
I attach all pics about template
Go to: CCM->Services-><your service>->Modify->Check Settings tab
and show us a screenshot of this page.
morabanc
Post by morabanc »
I see now .... :?
Solved !!!
