Httpd Can't start
zik
Httpd Can't start
Post by zik »
Good Day ,
I fixed one problem and I still have small one , if you can help me .
When I start the service httpd gave me this error:
httpd: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1 for ServerName
(2)No such file or directory: httpd: could not open error log file /etc/httpd/logs/error_log.
Unable to open logs
Normaly I cheked in hosts file I have like in the past :
127.0.0.1 Nagiose localhost.localdomain localhost
Searching in google I found that they recomend to add ServerName localhost in httpd.conf file ?
Many Thanks
All The Best
Re: Httpd Can't start
Post by slansing »
Yes, google was correct :) This should fix your issue, HTTPD should be started but it will give you that notification, which can be annoying.
zik
Post by zik »
excuse me what they mean ServerName localhost ? mean DNS server name ? and in the past I didn't touch this file httpd and it working .
You may get this message:
but the httpd may still be running.
What do you have in the hosts file?
cat /etc/hosts
Do you have something like this?
127.0.0.1       localhost   localhost.localdomain   localhost4    localhost4.localdomain4
::1             localhost   localhost.localdomain   localhost6    localhost6.localdomain6
zik
Post by zik »
In the hosts file I have like this :
10.5.5.1   Server.domainename.com      Server
can you help me please .
Many Thanks
zik
Post by zik »
good day ,
can somone help me or advice me , I will be thankful .
Many Thanks
Regards
Post by slansing »
All you need to do is change it to look like what Lmiltchev showed, do not change the IP's though.
zik
Post by zik »
excuse me after cheking:
[root@server etc]# ls -l /etc/httpd/
total 8
drwxr-xr-x 2 root   root   4096 févr. 26  2010 conf
drwxr-xr-x 2 root   root   4096 janv. 12  2010 conf.d
lrwxrwxrwx 1 nagios apache   19 déc. 22  2009 logs -> ../../var/log/httpd
lrwxrwxrwx 1 root   root     27 déc. 22  2009 modules -> ../../usr/lib/httpd/modules
lrwxrwxrwx 1 root   root     13 déc. 22  2009 run -> ../../var/run
the line logs -> ../../var/log/httpd is red
[root@server log]# ls -l /var/log/httpd/
ls: no access /var/log/httpd/:No such file
maybe i don't have permission in the file ?
Many Thanks
Post by slansing »
You should have permissions to see the logs from root. However that is just what they are, logs, they should not prevent HTTPD from starting on their own, you need to make the changes we suggested and then we will work on your other issue. Have you ever seen the Nagios Core web UI from this system? Or is this a fresh install.
Lets also check to see if the distro's install of apache did not place them somewhere else..:
Run the following and place the output back here:
ls -al /etc/httpd/logs
What Distro and version of Nagios Core are you using?
zik
Post by zik »
thank you very much .
no this is an old server because in the past I had one problem that logs was full , so the server can start , delete all logs maybe by mistake I delete the httpd
the version of nagios is :Nagios Core 3.2.0
[root@server log]# ls -al /etc/httpd/logs
lrwxrwxrwx 1 nagios apache 19 déc. 22  2009 /etc/httpd/logs -> ../../var/log/httpd
give me the line with color red strange
it s possible to reinstall and install httpd ?
Many Thanks
