cannot import MIBS
shakra2005
cannot import MIBS
HI,
i would try to import mibs but i have this error
MIB could not be installed - directory permissions may be incorrect.
Can anyone help me ?
Re: cannot import MIBS
Can you show us the output for the following?
ll /usr/share/snmp
ll /usr/share/snmp/mibs-
shakra2005
ll /usr/share/snmp
-rwxrwxrwx 1 root root 100105 Feb 12 22:00 cisco.conf
-rwxrwxrwx 1 root root 11494 Feb 12 22:00 cpq.conf
-rwxrwxrwx 1 root root 26458 Feb 12 22:00 hp.conf
-rwxrwxrwx 1 root root 6678 Jul 23 2012 mib2c.access_functions.conf
-rwxrwxrwx 1 root root 37814 Jul 23 2012 mib2c.array-user.conf
-rwxrwxrwx 1 root root 4705 Jul 23 2012 mib2c.check_values.conf
-rwxrwxrwx 1 root root 2527 Jul 23 2012 mib2c.check_values_local.conf
-rwxrwxrwx 1 root root 393 Jul 23 2012 mib2c.column_defines.conf
-rwxrwxrwx 1 root root 664 Jul 23 2012 mib2c.column_enums.conf
-rwxrwxrwx 1 root root 806 Jul 23 2012 mib2c.column_storage.conf
-rwxrwxrwx 1 root root 12200 Jul 23 2012 mib2c.conf
-rwxrwxrwx 1 root root 28245 Jul 23 2012 mib2c.container.conf
-rwxrwxrwx 1 root root 3593 Jul 23 2012 mib2c.create-dataset.conf
drwxrwxrwx 2 root root 4096 Aug 22 18:04 mib2c-data
-rwxrwxrwx 1 root root 8164 Jul 23 2012 mib2c.emulation.conf
-rwxrwxrwx 1 root root 8498 Jul 23 2012 mib2c.genhtml.conf
-rwxrwxrwx 1 root root 3200 Jul 23 2012 mib2c.int_watch.conf
-rwxrwxrwx 1 root root 15279 Jul 23 2012 mib2c.iterate_access.conf
-rwxrwxrwx 1 root root 20913 Jul 23 2012 mib2c.iterate.conf
-rwxrwxrwx 1 root root 1014 Jul 23 2012 mib2c.mfd.conf
-rwxrwxrwx 1 root root 2139 Jul 23 2012 mib2c.notify.conf
-rwxrwxrwx 1 root root 9259 Jul 23 2012 mib2c.old-api.conf
-rwxrwxrwx 1 root root 8777 Jul 23 2012 mib2c.perl.conf
-rwxrwxrwx 1 root root 19507 Jul 23 2012 mib2c.raw-table.conf
-rwxrwxrwx 1 root root 7211 Jul 23 2012 mib2c.row.conf
-rwxrwxrwx 1 root root 4572 Jul 23 2012 mib2c.scalar.conf
-rwxrwxrwx 1 root root 20422 Jul 23 2012 mib2c.table_data.conf
drwxrwsrwx. 2 root nagios 24576 Feb 18 15:18 mibs
-rwxrwxrwx 1 root root 2249 Feb 12 22:00 net-snmp.conf
-rwxrwxrwx 1 root root 134279 Feb 12 22:00 nwalarm.conf
-rwxrwxrwx 1 root root 1318 Feb 12 22:02 powernet.conf
-rwxrwxrwx 1 root root 2481 Feb 12 22:00 rfc.conf
drwxrwxrwx. 5 root root 4096 Jul 23 2012 snmpconf-data
-rwxrwxrwx 1 root root 18861 Feb 12 22:00 snmpd.conf
-rwxrwxrwx 1 root root 145 Jul 23 2012 snmp_perl.pl
-rwxrwxrwx 1 root root 431 Jul 23 2012 snmp_perl_trapd.pl
-rwxrwxrwx 1 root root 67 Feb 12 22:00 snmptrapd.conf
-rwxrwxrwx 1 root root 34257 Feb 12 22:00 snmptt.conf
-rwxrwxrwx 1 root root 42152 Feb 12 22:00 vmware.conf
wxrwxrwx 1 root nagios 46286 Jul 23 2012 IP-FORWARD-MIB.txt
-rwxrwxrwx 1 root nagios 185667 Jul 23 2012 IP-MIB.txt
-rwxrwxrwx 1 root nagios 15936 Jul 23 2012 IPV6-ICMP-MIB.txt
-rwxrwxrwx 1 root nagios 48703 Jul 23 2012 IPV6-MIB.txt
-rwxrwxrwx 1 root nagios 7257 Jul 23 2012 IPV6-TCP-MIB.txt
-rwxrwxrwx 1 root nagios 2367 Jul 23 2012 IPV6-TC.txt
-rwxrwxrwx 1 root nagios 4400 Jul 23 2012 IPV6-UDP-MIB.txt
-rwxrwxrwx 1 root nagios 788 Feb 12 09:37 LEFTHAND-NETWORKS-GLOBAL-REG-MIB.cfg
-rwxrwxrwx 1 root nagios 4135 Feb 12 09:37 LEFTHAND-NETWORKS-GLOBAL-REG-MIB.mib
-rwxrwxrwx 1 root nagios 76637 Feb 12 09:37 LEFTHAND-NETWORKS-NSM-CLUSTERING-MIB.cfg
-rwxrwxrwx 1 root nagios 117501 Feb 12 09:37 LEFTHAND-NETWORKS-NSM-CLUSTERING-MIB.mib
-rwxrwxrwx 1 root nagios 4619 Feb 12 09:37 LEFTHAND-NETWORKS-NSM-DNS-MIB.cfg
-rwxrwxrwx 1 root nagios 8855 Feb 12 09:37 LEFTHAND-NETWORKS-NSM-DNS-MIB.mib
-rwxrwxrwx 1 root nagios 30493 Feb 12 09:37 LEFTHAND-NETWORKS-NSM-INFO-MIB.cfg
-rwxrwxrwx 1 root nagios 48084 Feb 12 09:37 LEFTHAND-NETWORKS-NSM-INFO-MIB.mib
-rwxrwxrwx 1 root nagios 1414 Feb 12 09:37 LEFTHAND-NETWORKS-NSM-MIB.cfg
-rwxrwxrwx 1 root nagios 7070 Feb 12 09:37 LEFTHAND-NETWORKS-NSM-MIB.mib
-rwxrwxrwx 1 root nagios 4264 Feb 12 09:37 LEFTHAND-NETWORKS-NSM-NETWORK-MIB.cfg
-rwxrwxrwx 1 root nagios 9815 Feb 12 09:37 LEFTHAND-NETWORKS-NSM-NETWORK-MIB.mib
-rwxrwxrwx 1 root nagios 40058 Feb 12 09:37 LEFTHAND-NETWORKS-NSM-NOTIFICATION-MIB.cfg
-rwxrwxrwx 1 root nagios 63774 Feb 12 09:37 LEFTHAND-NETWORKS-NSM-NOTIFICATION-MIB.mib
-rwxrwxrwx 1 root nagios 3488 Feb 12 09:37 LEFTHAND-NETWORKS-NSM-NTP-MIB.cfg
-rwxrwxrwx 1 root nagios 7402 Feb 12 09:37 LEFTHAND-NETWORKS-NSM-NTP-MIB.mib
-rwxrwxrwx 1 root nagios 12287 Feb 12 09:37 LEFTHAND-NETWORKS-NSM-SECURITY-MIB.cfg
-rwxrwxrwx 1 root nagios 19748 Feb 12 09:37 LEFTHAND-NETWORKS-NSM-SECURITY-MIB.mib
-rwxrwxrwx 1 root nagios 2487 Feb 12 09:37 LEFTHAND-NETWORKS-NSM-STATUS-MIB.cfg
-rwxrwxrwx 1 root nagios 5822 Feb 12 09:37 LEFTHAND-NETWORKS-NSM-STATUS-MIB.mib
-rwxrwxrwx 1 root nagios 16788 Feb 12 09:37 LEFTHAND-NETWORKS-NSM-STORAGE-MIB.cfg
-rwxrwxrwx 1 root nagios 27972 Feb 12 09:37 LEFTHAND-NETWORKS-NSM-STORAGE-MIB.mib
-rwxrwxrwx 1 root nagios 5931 Jul 23 2012 LM-SENSORS-MIB.txt
-rwxrwxrwx 1 root nagios 24496 Feb 12 09:37 lsf001.cfg
-rwxrwxrwx 1 root nagios 27215 Feb 12 09:37 lsf001.mib
-rwxrwxrwx 1 root nagios 336 Feb 12 09:37 mibcore.list
-rwxrwxrwx 1 root nagios 2228 Feb 12 09:37 mibreadme.txt
-rwxrwxrwx 1 root nagios 77541 Feb 12 09:37 mlxraid.cfg
-rwxrwxrwx 1 root nagios 106471 Feb 12 09:37 mlxraid.mib
-rwxrwxrwx 1 root nagios 2953 Feb 12 09:37 msa2000traps.cfg
-rwxrwxrwx 1 root nagios 4278 Feb 12 09:37 msa2000traps.mib
-rwxrwxrwx 1 root nagios 42375 Jul 23 2012 MTA-MIB.txt
-rwxrwxrwx 1 root nagios 19760 Aug 29 2011 NAGIOS-NOTIFY-MIB.txt
-rwxrwxrwx 1 root nagios 2093 Aug 29 2011 NAGIOS-ROOT-MIB.txt
-rwxrwxrwx 1 root nagios 66608 Feb 12 09:37 ndstrap.cfg
-rwxrwxrwx 1 root nagios 95582 Feb 12 09:37 ndstrap.mib
-rwxrwxrwx 1 root nagios 15732 Jul 23 2012 NET-SNMP-AGENT-MIB.txt
-rwxrwxrwx 1 root nagios 9160 Jul 23 2012 NET-SNMP-EXAMPLES-MIB.txt
-rwxrwxrwx 1 root nagios 9198 Jul 23 2012 NET-SNMP-EXTEND-MIB.txt
-rwxrwxrwx 1 root nagios 2036 Jul 23 2012 NET-SNMP-MIB.txt
-rwxrwxrwx 1 root nagios 3351 Jul 23 2012 NET-SNMP-PASS-MIB.txt
-rwxrwxrwx 1 root nagios 4686 Jul 23 2012 NET-SNMP-TC.txt
-rwxrwxrwx 1 root nagios 5039 Jul 23 2012 NET-SNMP-VACM-MIB.txt
-rwxrwxrwx 1 root nagios 21006 Jul 23 2012 NETWORK-SERVICES-MIB.txt
-rwxrwxrwx 1 root nagios 24694 Jul 23 2012 NOTIFICATION-LOG-MIB.txt
-rwxrwxrwx 1 root nagios 2083 Feb 12 09:37 nsaasr.cfg
-rwxrwxrwx 1 root nagios 5967 Feb 12 09:37 nsaasr.mib
-rwxrwxrwx 1 root nagios 7800 Feb 12 09:37 nsadimm.cfg
-rwxrwxrwx 1 root nagios 18079 Feb 12 09:37 nsadimm.mib
-rwxrwxrwx 1 root nagios 20140 Feb 12 09:37 nsaevent.cfg
-rwxrwxrwx 1 root nagios 32253 Feb 12 09:37 nsaevent.mib
-rwxrwxrwx 1 root nagios 15534 Feb 12 09:37 nsainfo.cfg
-rwxrwxrwx 1 root nagios 33940 Feb 12 09:37 nsainfo.mib
-rwxrwxrwx 1 root nagios 20471 Feb 12 09:37 nsapci.cfg
-rwxrwxrwx 1 root nagios 40438 Feb 12 09:37 nsapci.mib
-rwxrwxrwx 1 root nagios 696 Feb 12 09:37 nsarps.cfg
-rwxrwxrwx 1 root nagios 2174 Feb 12 09:37 nsarps.mib
-rwxrwxrwx 1 root nagios 9305 Feb 12 09:37 nsascsi.cfg
-rwxrwxrwx 1 root nagios 22259 Feb 12 09:37 nsascsi.mib
-rwxrwxrwx 1 root nagios 3595 Feb 12 09:37 nsatrcfg.cfg
-rwxrwxrwx 1 root nagios 9135 Feb 12 09:37 nsatrcfg.mib
-rwxrwxrwx 1 root nagios 9917 Feb 12 09:37 nsatrmgr.cfg
-rwxrwxrwx 1 root nagios 16880 Feb 12 09:37 nsatrmgr.mib
-rwxrwxrwx 1 root nagios 8783 Feb 12 09:37 nsavolcp.cfg
-rwxrwxrwx 1 root nagios 19575 Feb 12 09:38 nsavolcp.mib
-rwxrwxrwx 1 root nagios 52265 Feb 12 09:38 nsnicmib.cfg
-rwxrwxrwx 1 root nagios 96241 Feb 12 09:38 nsnicmib.mib
-rwxrwxrwx 1 root nagios 206265 Feb 12 09:38 nwalarm.cfg
-rwxrwxrwx 1 root nagios 235257 Feb 12 09:38 nwalarm.mib
-rwxrwxrwx 1 root nagios 57338 Feb 12 09:38 nwserver.cfg
-rwxrwxrwx 1 root nagios 92615 Feb 12 09:38 nwserver.mib
-rwxrwxrwx 1 root nagios 35955 Feb 12 09:38 old-cisco-chassis.cfg
-rwxrwxrwx 1 root nagios 125074 Feb 12 09:38 old-cisco-chassis.mib
-rwxrwxrwx 1 root nagios 5129 Feb 12 09:38 old-cisco-flash.cfg
-rwxrwxrwx 1 root nagios 11883 Feb 12 09:38 old-cisco-flash.mib
-rwxrwxrwx 1 root nagios 24982 Feb 12 09:38 old-cisco-interfaces.cfg
-rwxrwxrwx 1 root nagios 53192 Feb 12 09:38 old-cisco-interfaces.mib
-rwxrwxrwx 1 root nagios 7505 Feb 12 09:38 old-cisco-ip.cfg
-rwxrwxrwx 1 root nagios 16697 Feb 12 09:38 old-cisco-ip.mib
-rwxrwxrwx 1 root nagios 19612 Feb 12 09:38 old-cisco-sys.cfg
-rwxrwxrwx 1 root nagios 41678 Feb 12 09:38 old-cisco-sys.mib
-rwxrwxrwx 1 root nagios 2159 Feb 12 09:38 old-cisco-tcp.cfg
-rwxrwxrwx 1 root nagios 4913 Feb 12 09:38 old-cisco-tcp.mib
-rwxrwxrwx 1 root nagios 8942 Feb 12 09:38 old-cisco-ts.cfg
-rwxrwxrwx 1 root nagios 20467 Feb 12 09:38 old-cisco-ts.mib
-rwxrwxrwx 1 root nagios 3215 Feb 12 09:38 ovis-v2.cfg
-rwxrwxrwx 1 root nagios 3467 Feb 12 09:38 ovis-v2.mib
-rwxrwxrwx 1 root nagios 5580 Feb 12 09:38 parselog.cfg
-rwxrwxrwx 1 root nagios 9984 Feb 12 09:38 parselog.mib
-rwxrwxrwx 1 root nagios 17299 Feb 12 09:38 p-bridge-mib.cfg
-rwxrwxrwx 1 root nagios 33486 Feb 12 09:38 p-bridge-mib.mib
-rwxrwxrwx 1 root nagios 39762 Feb 12 09:38 pcisnet.cfg
-rwxrwxrwx 1 root nagios 55405 Feb 12 09:38 pcisnet.mib
-rwxrwxrwx 1 root nagios 17715 Feb 12 09:38 pfc.cfg
-rwxrwxrwx 1 root nagios 28658 Feb 12 09:38 pfc.mib
-rw-r--r-- 1 root nagios 2030498 Nov 18 2009 powernet398.mib
-rwxrwxrwx 1 root nagios 2241197 Feb 12 21:54 powernet405.mib
-rwxrwxrwx 1 root nagios 90595 Feb 12 09:38 powernet.cfg
-rwxrwxrwx 1 root nagios 105670 Feb 12 09:38 powernet.mib
-rwxrwxrwx 1 root nagios 2608 Feb 12 09:38 preloadm.list
-rwxrwxrwx 1 root nagios 43131 Feb 12 09:38 q-bridge.cfg
-rwxrwxrwx 1 root nagios 69164 Feb 12 09:38 q-bridge.mib
-rwxrwxrwx 1 root nagios 6016 Feb 12 09:38 qlogicmib2.cfg
-rwxrwxrwx 1 root nagios 9845 Feb 12 09:38 qlogicmib2.mib
-rwxrwxrwx 1 root nagios 146017 Feb 12 09:38 radlan-mib.cfg
-rwxrwxrwx 1 root nagios 195066 Feb 12 09:38 radlan-mib.mib
-rwxrwxrwx 1 root nagios 65 Feb 12 09:38 rfc1155.cfg
-rwxrwxrwx 1 root nagios 756 Feb 12 09:38 rfc1155.mib
-rwxrwxrwx 1 root nagios 69 Feb 12 09:38 rfc1155-smi.cfg
-rwxrwxrwx 1 root nagios 76 Feb 12 09:38 rfc1155-smi.mib
-rwxrwxrwx 1 root nagios 3067 Jul 23 2012 RFC1155-SMI.txt
-rwxrwxrwx 1 root nagios 27050 Feb 12 09:38 rfc1158.cfg
-rwxrwxrwx 1 root nagios 53976 Feb 12 09:38 rfc1158.mib
-rwxrwxrwx 1 root nagios 63 Feb 12 09:38 rfc-1212.cfg
-rwxrwxrwx 1 root nagios 62 Feb 12 09:38 rfc1212.cfg
-rwxrwxrwx 1 root nagios 73 Feb 12 09:38 rfc-1212.mib
-rwxrwxrwx 1 root nagios 73 Feb 12 09:38 rfc1212.mib
-rwxrwxrwx 1 root nagios 57211 Feb 12 09:38 rfc-1213.cfg
-rwxrwxrwx 1 root nagios 57210 Feb 12 09:38 rfc1213.cfg
-rwxrwxrwx 1 root nagios 3373 Feb 12 09:38 rfc-1215.cfg
-rwxrwxrwx 1 root nagios 3371 Feb 12 09:38 rfc1215.cfg
-rwxrwxrwx 1 root nagios 3776 Feb 12 09:38 rfc-1215.mib
-rwxrwxrwx 1 root nagios 3878 Feb 12 09:38 rfc1215.mib
-rwxrwxrwx 1 root nagios 1174 Jul 23 2012 RFC-1215.txt
-rwxrwxrwx 1 root nagios 87960 Feb 12 09:38 rfc1271-mib.cfg
-rwxrwxrwx 1 root nagios 151031 Feb 12 09:38 rfc1271-mib.mib
-rwxrwxrwx 1 root nagios 33902 Feb 12 09:38 rfc1514.cfg
-rwxrwxrwx 1 root nagios 52368 Feb 12 09:38 rfc1514.mib
-rwxrwxrwx 1 root nagios 155364 Feb 12 09:38 rmon2-mib.cfg
-rwxrwxrwx 1 root nagios 212727 Feb 12 09:38 rmon2-mib.mib
-rwxrwxrwx 1 root nagios 99712 Feb 12 09:38 rmon-mib.cfg
-rwxrwxrwx 1 root nagios 155263 Feb 12 09:38 rmon-mib.mib
-rwxrwxrwx 1 root nagios 147822 Jul 23 2012 RMON-MIB.txt
-rwxrwxrwx 1 root nagios 45323 Jul 23 2012 SCTP-MIB.txt
-rwxrwxrwx 1 root nagios 45134 Feb 12 09:38 smsagent.cfg
-rwxrwxrwx 1 root nagios 50839 Feb 8 13:57 smsagent.mib
-rwxrwxrwx 1 root nagios 4595 Jul 23 2012 SMUX-MIB.txt
-rwxrwxrwx 1 root nagios 15490 Jul 23 2012 SNMP-COMMUNITY-MIB.txt
-rwxrwxrwx 1 root nagios 3355 Feb 12 09:38 snmp-framework-mib.cfg
-rwxrwxrwx 1 root nagios 22892 Feb 12 09:38 snmp-framework-mib.mib
-rwxrwxrwx 1 root nagios 22342 Jul 23 2012 SNMP-FRAMEWORK-MIB.txt
-rwxrwxrwx 1 root nagios 1696 Feb 12 09:38 snmp-mpd-mib.cfg
-rwxrwxrwx 1 root nagios 5783 Feb 12 09:38 snmp-mpd-mib.mib
-rwxrwxrwx 1 root nagios 5496 Jul 23 2012 SNMP-MPD-MIB.txt
-rwxrwxrwx 1 root nagios 11438 Feb 12 09:38 snmp-notification-mib.cfg
-rwxrwxrwx 1 root nagios 21242 Feb 12 09:38 snmp-notification-mib.mib
-rwxrwxrwx 1 root nagios 20014 Jul 23 2012 SNMP-NOTIFICATION-MIB.txt
-rwxrwxrwx 1 root nagios 9106 Jul 23 2012 SNMP-PROXY-MIB.txt
-rwxrwxrwx 1 root nagios 11655 Feb 12 09:38 snmp-target-mib.cfg
-rwxrwxrwx 1 root nagios 23837 Feb 12 09:38 snmp-target-mib.mib
-rwxrwxrwx 1 root nagios 22769 Jul 23 2012 SNMP-TARGET-MIB.txt
-rwxrwxrwx 1 root nagios 39201 Jul 23 2012 SNMP-USER-BASED-SM-MIB.txt
-rwxrwxrwx 1 root nagios 2205 Jul 23 2012 SNMP-USM-AES-MIB.txt
-rwxrwxrwx 1 root nagios 21101 Jul 23 2012 SNMP-USM-DH-OBJECTS-MIB.txt
-rwxrwxrwx 1 root nagios 69 Feb 12 09:38 snmpv2-conf.cfg
-rwxrwxrwx 1 apache apache 267 Feb 12 09:38 SNMPv2-CONF.mib
-rwxrwxrwx 1 root nagios 8263 Jul 23 2012 SNMPv2-CONF.txt
-rwxrwxrwx 1 root nagios 18226 Feb 12 09:38 snmpv2-mib.cfg
-rwxrwxrwx 1 apache apache 32788 Feb 12 09:38 snmpv2-mib.mib
-rwxrwxrwx 1 root nagios 29305 Jul 23 2012 SNMPv2-MIB.txt
-rwxrwxrwx 1 root nagios 744 Feb 12 09:38 snmpv2-smi.cfg
-rwxrwxrwx 1 root nagios 1398 Feb 12 09:38 SNMPv2-SMI.mib
-rwxrwxrwx 1 root nagios 8924 Jul 23 2012 SNMPv2-SMI.txt
-rwxrwxrwx 1 root nagios 666 Feb 12 09:38 SNMPv2-SMI-v1.cfg
-rwxrwxrwx 1 apache apache 1414 Feb 12 09:38 SNMPv2-SMI-v1.mib
-rwxrwxrwx 1 root nagios 840 Feb 12 09:38 snmpv2-tc.cfg
-rwxrwxrwx 1 root nagios 35911 Feb 12 09:38 SNMPv2-TC.mib
-rwxrwxrwx 1 root nagios 38034 Jul 23 2012 SNMPv2-TC.txt
-rwxrwxrwx 1 root nagios 603 Feb 12 09:38 snmpv2-tc-v1.cfg
-rwxrwxrwx 1 root nagios 2544 Feb 12 09:38 snmpv2-tc-v1.mib
-rwxrwxrwx 1 root nagios 5775 Jul 23 2012 SNMPv2-TM.txt
-rwxrwxrwx 1 root nagios 34162 Jul 23 2012 SNMP-VIEW-BASED-ACM-MIB.txt
-rwxrwxrwx 1 root nagios 7967 Feb 12 09:38 svrclu.cfg
-rwxrwxrwx 1 root nagios 13710 Feb 12 09:38 svrclu.mib
-rwxrwxrwx 1 root nagios 47802 Feb 12 09:38 svrmgt.cfg
-rwxrwxrwx 1 root nagios 62043 Feb 12 09:38 svrmgt.mib
-rwxrwxrwx 1 root nagios 5491 Feb 8 13:57 svrntc.cfg
-rwxrwxrwx 1 root nagios 9721 Feb 18 14:29 svrntc.mib
-rwxrwxrwx 1 root nagios 40307 Feb 8 13:57 switch.cfg
-rwxrwxrwx 1 root nagios 54840 Feb 12 09:38 switch.mib
-rwxrwxrwx 1 root nagios 10038 Feb 12 09:38 symtrap.cfg
-rwxrwxrwx 1 root nagios 21988 Feb 12 09:38 symtrap.mib
-rwxrwxrwx 1 root nagios 12003 Feb 12 09:38 tcp.mib
-rwxrwxrwx 1 root nagios 6932 Feb 12 09:38 tcp-mib.cfg
-rwxrwxrwx 1 root nagios 11980 Feb 12 09:38 tcp-mib.mib
-rwxrwxrwx 1 root nagios 28564 Jul 23 2012 TCP-MIB.txt
-rwxrwxrwx 1 root nagios 12407 Feb 12 09:38 token.cfg
-rwxrwxrwx 1 root nagios 28476 Feb 12 09:38 token.mib
-rwxrwxrwx 1 root nagios 61960 Feb 12 09:38 token-ring-rmon-mib.cfg
-rwxrwxrwx 1 root nagios 73577 Feb 12 09:38 token-ring-rmon-mib.mib
-rwxrwxrwx 1 root nagios 2822 Feb 12 09:38 TRANSPORT-ADDRESS-MIB.cfg
-rwxrwxrwx 1 root nagios 16808 Feb 12 09:38 TRANSPORT-ADDRESS-MIB.mib
-rwxrwxrwx 1 root nagios 16418 Jul 23 2012 TRANSPORT-ADDRESS-MIB.txt
-rwxrwxrwx 1 root nagios 32273 Feb 12 09:38 truclu.cfg
-rwxrwxrwx 1 root nagios 53624 Feb 12 09:38 truclu.mib
-rwxrwxrwx 1 root nagios 2163 Jul 23 2012 UCD-DEMO-MIB.txt
-rwxrwxrwx 1 root nagios 4402 Jul 23 2012 UCD-DISKIO-MIB.txt
-rwxrwxrwx 1 root nagios 3010 Jul 23 2012 UCD-DLMOD-MIB.txt
-rwxrwxrwx 1 root nagios 8118 Jul 23 2012 UCD-IPFWACC-MIB.txt
-rwxrwxrwx 1 root nagios 26581 Feb 12 09:38 ucd-snmp-mib.cfg
-rwxrwxrwx 1 root nagios 36651 Feb 12 09:38 ucd-snmp-mib.mib
-rwxrwxrwx 1 root nagios 46150 Jul 23 2012 UCD-SNMP-MIB.txt
-rwxrwxrwx 1 root nagios 11822 Feb 12 09:38 udp-mib.cfg
-rwxrwxrwx 1 root nagios 22861 Feb 12 09:38 udp-mib.mib
-rwxrwxrwx 1 root nagios 20882 Jul 23 2012 UDP-MIB.txt
-rwxrwxrwx 1 root nagios 1398 Feb 12 09:38 ums.cfg
-rwxrwxrwx 1 root nagios 1984 Feb 12 09:38 ums.mib
-rwxrwxrwx 1 root nagios 38273 Feb 12 09:38 unified.cfg
-rwxrwxrwx 1 root nagios 61436 Feb 12 09:38 unified.mib
-rwxrwxrwx 1 root nagios 267 Feb 12 09:38 upg52t521.list
-rwxrwxrwx 1 root nagios 198 Feb 12 09:38 upg52t53.list
-rwxrwxrwx 1 root nagios 24 Feb 12 09:38 upg53t531.list
-rwxrwxrwx 1 root nagios 506 Feb 12 09:38 upg53t54.list
-rwxrwxrwx 1 root nagios 120 Feb 12 09:38 upgmibs.list
-rwxrwxrwx 1 root nagios 14826 Feb 12 09:38 v5_0ficon.cfg
-rwxrwxrwx 1 root nagios 24048 Feb 12 09:38 v5_0ficon.mib
-rwxrwxrwx 1 root nagios 10989 Feb 12 09:38 v5_1ha.cfg
-rwxrwxrwx 1 root nagios 9102 Feb 12 09:38 v5_1ha.mib
-rwxrwxrwx 1 root nagios 80019 Feb 12 09:38 v5_3sw.cfg
-rwxrwxrwx 1 root nagios 91664 Feb 12 09:38 v5_3sw.mib
-rwxrwxrwx 1 root nagios 29857 Feb 12 09:38 vc-domain-mib.cfg
-rwxrwxrwx 1 root nagios 43836 Feb 12 09:38 vc-domain-mib.mib
-rwxrwxrwx 1 root nagios 11470 Feb 12 09:38 vc-module-mib.cfg
-rwxrwxrwx 1 root nagios 17910 Feb 12 09:38 vc-module-mib.mib
-rwxrwxrwx 1 root nagios 338 Feb 12 09:38 VMWARE-AGENTCAP-MIB.cfg
-rwxrwxrwx 1 root nagios 20814 Feb 12 09:38 VMWARE-AGENTCAP-MIB.mib
-rwxrwxrwx 1 root nagios 879 Feb 12 09:38 VMWARE-CIMOM-MIB.cfg
-rwxrwxrwx 1 apache apache 2338 Feb 12 09:38 VMWARE-CIMOM-MIB.mib
-rwxrwxrwx 1 root nagios 14871 Feb 12 09:38 VMWARE-ENV-MIB.cfg
-rwxrwxrwx 1 root nagios 22411 Feb 12 09:38 VMWARE-ENV-MIB.mib
-rwxrwxrwx 1 root nagios 11404 Feb 12 09:38 VMWARE-OBSOLETE-MIB.cfg
-rwxrwxrwx 1 root nagios 15670 Feb 12 09:38 VMWARE-OBSOLETE-MIB.mib
-rwxrwxrwx 1 root nagios 601 Feb 12 09:38 VMWARE-PRODUCTS-MIB.cfg
-rwxrwxrwx 1 root nagios 1424 Feb 12 09:38 VMWARE-PRODUCTS-MIB.mib
-rwxrwxrwx 1 root nagios 6884 Feb 12 09:38 VMWARE-RESOURCES-MIB.cfg
-rwxrwxrwx 1 apache apache 8306 Feb 12 09:38 VMWARE-RESOURCES-MIB.mib
-rwxrwxrwx 1 root nagios 738 Feb 12 09:38 VMWARE-ROOT-MIB.cfg
-rwxrwxrwx 1 root nagios 3072 Feb 12 09:38 VMWARE-ROOT-MIB.mib
-rwxrwxrwx 1 root nagios 2644 Feb 12 09:38 VMWARE-SYSTEM-MIB.cfg
-rwxrwxrwx 1 root nagios 3872 Feb 12 09:38 VMWARE-SYSTEM-MIB.mib
-rwxrwxrwx 1 root nagios 1833 Feb 12 09:38 VMWARE-TC-MIB.cfg
-rwxrwxrwx 1 apache apache 6800 Feb 12 09:38 VMWARE-TC-MIB.mib
-rwxrwxrwx 1 root nagios 2835 Feb 12 09:38 VMWARE-TRAPS-MIB.cfg
-rwxrwxrwx 1 apache apache 4004 Feb 12 09:38 VMWARE-TRAPS-MIB.mib
-rwxrwxrwx 1 root nagios 5178 Feb 12 09:38 VMWARE-VC-EVENT-MIB.cfg
-rwxrwxrwx 1 apache apache 8772 Feb 12 09:38 VMWARE-VC-EVENT-MIB.mib
-rwxrwxrwx 1 root nagios 18692 Feb 12 09:38 VMWARE-VMINFO-MIB.cfg
-rwxrwxrwx 1 root nagios 27003 Feb 12 09:38 VMWARE-VMINFO-MIB.mib
-rwxrwxrwx 1 root nagios 514 Feb 12 09:38 VMWARE-VMKERNEL-MIB.cfg
-rwxrwxrwx 1 apache apache 774 Feb 12 09:38 VMWARE-VMKERNEL-MIB.mib
-rwxrwxrwx 1 root nagios 77958 Feb 12 09:38 wbt3mib.cfg
-rwxrwxrwx 1 root nagios 128907 Feb 12 09:38 wbt3mib.mib
-rwxrwxrwx 1 root nagios 1476 Feb 12 09:38 xp1024trapmib.cfg
-rwxrwxrwx 1 root nagios 1806 Feb 18 14:27 xp1024trapmib.mib
-rwxrwxrwx 1 root nagios 6935 Feb 12 09:38 zesa.cfg
-rwxrwxrwx 1 root nagios 9209 Feb 12 09:38 zesa.mib
-rwxrwxrwx 1 root nagios 52211 Feb 12 09:38 zhrm.cfg
-rwxrwxrwx 1 root nagios 71118 Feb 12 09:38 zhrm.mib
-rwxrwxrwx 1 root nagios 12981 Feb 12 09:38 zsmp.cfg
-rwxrwxrwx 1 root nagios 25085 Feb 12 09:38 zsmp.mib
-rwxrwxrwx 1 root nagios 8475 Feb 12 09:38 ztmx.cfg
-rwxrwxrwx 1 root nagios 12111 Feb 12 09:38 ztmx.mib
-rwxrwxrwx 1 root nagios 9283 Feb 12 09:38 ztsa.cfg
-rwxrwxrwx 1 root nagios 14625 Feb 12 09:38 ztsa.mib-
What MIB are you attempting to upload? What version of Nagios XI are you running?
shakra2005
i want to upload the powernet405.mib and i use NagiosXI 2012R 1.6
Have you tried using anything which requires this MIB yet? It looks like it is in the directory:
-rwxrwxrwx 1 root nagios 2241197 Feb 12 21:54 powernet405.mib-
shakra2005
yes but it dont work
-rwxrwxrwx 1 root nagios 2241197 Feb 12 21:54 /usr/share/snmp/mibs/powernet405.mib
when i try to upload from my windows machine it dont work too
For good measure lets run the following:
Though it is already there as I showed you above.
chown root:nagios /usr/share/snmp/mibs
chmod g+w /usr/share/snmp/mibs-
This mib is already in the directory list you showed above, there is no need to re-upload it.
shakra2005
okay i have run the two commands.
now its to import the mib in Nagios.
I would like to monitor a APC USV
can you tell me how to import in nagios ?
when i run snmpwalk -v1 -c public localhost
i cannot see the mib
snmptranslate powernet405.mib
powernet405.mib: Unknown Object Identifier (Sub-id not found: (top) -> powernet405)
