I am having problems where the value for my custom variables is not being passed to the command properly.
Here is the command that I have setup:
Here is the template we have added it to:
Here is the service check we attached it to and its custom variables:
For some odd reason it fails because the custom variables aren't recognized and just return a value of "$". It is kind of confusing because we have used the same thing for other checks for drive space and cpu. It works flawlessly. For some reason we are having all sorts of problems with this web check. Any ideas why the command is only getting the $ for a value for the variables?
Custom variables returning "$"
Our installation is currently:
CentOS Linux release 6.0 (Final)
32 bit
VM Image
Special Configurations: No
32 bit
VM Image
Re: Custom variables returning "$"
use
instead of
$_SERVICEURL$Code: Select all
$_URL$Re: Custom variables returning "$"
well I feel stupid haha.. thanks for the quick response!
32 bit
VM Image
32 bit
VM Image
