Monitor process on remote Linux host?
scobi
Post by scobi »
Greetings! Having a bit of trouble getting the correct response to "check_procs". I believe I have the proper ARGs defined, but check returns "PROCS CRITICAL: 0 processes with command name blah blah blah".
Perhaps I'm making another n00b mistake?
$USER1$/check_procs -c $ARG1$ -C $ARG2$ --ereg-argument-array $ARG3$
$USER1$/check_procs -c 1:1 -C python --ereg-argument-array "my file.py us"
Yes, I really have no idea what I'm doing.
Thanks in advance for any help from the Nagios Pros...!!!
Re: Monitor process on remote Linux host?
This looks ok if you are looking for all python processes that have "my file.py us" exactly in the arguments of the command
can you run the following to see if said process exists
ps -ef|grep -v grep|grep python
scobi
Post by scobi »
It would appear so? :-)
nagios 1967 1 0 Feb16 ? 00:26:18 python /home/somefolder/MyFile.py us
Thanks!
scobi
Post by scobi »
Doh! I probably need to use nrpe for this, right?
Told you it was probably a n00b issue...
Is that my problem or just another way to get the result?
Thanks!
scobi wrote: I probably need to use nrpe for this, right?
yes if this is on a remote system....
