what is the difference between notification interval and check interval
if my check interval is set to 60 minutes and notification interval is set to 5 minutes...will i get notification every 5 minutes if the service goes in CRITICAL state.
notification interval vs check interval
maxwellmiranda
Re: notification interval vs check interval
Notification interval is the interval at which Nagios will send out notifications once a service or host goes into a downed state.
The check interval is the interval at which a check is ran via the Host / Service.
If you set your Notification interval to 5 minutes, you will be notified every 5 minutes until the issue is settled.
