check_mssql_monitor show unknown
cjimmy1977
Post by cjimmy1977 »
wanna to ask, i succesfuly install nagios and wanna to monitoring SQL server , so i download the plugins name check_mssql_monitor from http://exchange.nagios.org/directory/Pl ... or/details
i'm using root and copy to /usr/local/nagios/libexec and make it executable with chmod 777 check_mssql_monitor
in the terminal, i success use this plugin to check the SQL, with syntax ./check_mssql_monitor -H 10.1.10.91 -p 1433 -U jimmy -P jim123# -w 80 -c 90 and success show the result in terminal.
now, i try to put in commands.cfg and windows.cfg in nagios
in the commands.cfg:
define command
command_name check_mssql_monitor
command_line $USER1$/check_mssql_monitor -H $HOSTADDRESS$ -p 1433 -U jimmy -P jim123# --cpuwarning --cpucritical -w $ARG1$ -c $ARG2$
in windows.cfg:
define service
use generic service
host_name 10.1.10.91
service_description SQL Server CPU Process
check_command check_mssql_monitor!80!90!30
after i do the compile with /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg show no error and i restart the nagios service with /etc/init.d/nagios restart.
after restart i see the nagios front end , and the result show "UNKNOWN" Usage: check_mssql_monitor -H hostname [ -p port ] [ -t timeout ]
any help for this...
thanks
abrist
Red Shirt
Re: check_mssql_monitor show unknown
Post by abrist »
cjimmy1977 wrote:check_command check_mssql_monitor!80!90!30
Where does the "30" come from? I only count 2 arguments in the following:
cjimmy1977 wrote:./check_mssql_monitor -H 10.1.10.91 -p 1433 -U jimmy -P jim123# -w 80 -c 90
You could try:
