check_esx_host_vmfs plugin issue while monitoring ESXi DS
sunnysthakur
Post by sunnysthakur »
I setup a check_esx_host_vmfs plugin for monitoring datastore status on ESXi server. But on configuring this plugin, this is working fine but it displays "WARNING" status on UI of Nagios every time.
Currently my datastore size is 926.50 GB and right now free space available is 570.60 GB but still it showing warning on UI.
In command.cfg i mentioned the below one for this plugin.
        command_name check_esx_host_vmfs
        command_line $USER1$/check_esx3 -H $HOSTADDRESS$ -u $USER11$ -p $USER12$ -l vmfs -w $ARG2$ -c $ARG3$
In my services.cfg file i defined the below lines to check the status of datastore using the above mentioned command.
# check for datasource usage
        use                            generic-service
        action_url                     /nagiosgraph/cgi-bin/show.cgi?host=$HOSTNAME$&service=$SERVICEDESC$' onMouseOver='showGraphPopup(this)' onMouseOut='hi                                       deGraphPopup()' rel='/nagiosgraph/cgi-bin/showgraph.cgi?host=$HOSTNAME$&service=$SERVICEDESC$
        host_name                      ESXiserver
        service_description            ESXi Datasource Usage
        is_volatile                    0
        check_period                   24x7
        max_check_attempts             3
        normal_check_interval          3
        retry_check_interval           1
        contact_groups                 vmwareadmins
        notification_interval          120
        notification_period            24x7
        notification_options           u,c,r
        check_command                  check_esx_host_vmfs!90!98
Warning message is 90% and Critical is 98%, but right now its 61% but shows a warning on Nagios UI.
Is i am define something wrong here to setup this plugin or this is a bug in this.
abrist
Red Shirt
Re: check_esx_host_vmfs plugin issue while monitoring ESXi D
Post by abrist »
Try changing the check args to $ARG1$ and $ARG2$ instead of $ARG2$ and $ARG3$:
        command_line $USER1$/check_esx3 -H $HOSTADDRESS$ -u $USER11$ -p $USER12$ -l vmfs -w $ARG1$ -c $ARG2$
sunnysthakur
After changing to $ARG1$ and $ARG2$ WARNING message converts to CRITICAL now.
however i set the warning limit after 90% and critical limit after 95%. Currently datastore is consuming 61% space.
        use                            generic-service
        host_name                      Esxihost
        is_volatile                    0
        check_period                   24x7
        [b]check_command                  check_esx_host_vmfs!90!95[/b]
Below is the command which i changed to $ARG1$ and $ARG2$
I also checked this command by executing on bash and it shows CRITICAL.
[root@monitor nagios]# /usr/lib64/nagios/plugins/check_esx3 -H 104.10.50.218 -u admin -p password1234 -l vmfs -w 90 -c 95
CHECK_ESX3 CRITICAL - Storages : datastore1=584293.00 MB (61.59%) | datastore1=584293.00MB;90;95
Am i missing somewhere to define warning and critical limits as i have total 1 TB drive and after and currently 61% is filled but still it show critical.
sunnysthakur
After googling for this issue and found that the check_esx3 script is throwing WARNING and CRITICAL status if we use %age for datastore [w 90% and c 95%].
This works fine if we set triggers in MBs [Total size/trigger%] [ -w 853862 -c 901299]
/usr/lib64/nagios/plugins/check_esx3 -H 104.10.50.218 -u admin -p password1234 -l vmfs -o used -w 853862 -c 901299
CHECK_ESX3 OK - Storages : datastore1=364443 MB (38.41%) | datastore1=364443MB;853862;901299
# /usr/lib64/nagios/plugins/check_esx3 -H 10.0.0.218 -l vmfs -u supadmin -p Bebo1234 -l vmfs -o used
CHECK_ESX3 OK - Storages : datastore1=364443 MB (38.41%) | datastore1=364443MB;;
To set the trigger we have to define the -w and -c as per the disk capacity on each esx hosts.
Detail is given on this link
http://exchange.nagios.org/directory/Pl ... st/details
Better to fix this script to use %age instead of MBs
abrist
Red Shirt
Post by abrist »
Have you tried inverting the percentage, instead of "used" space, it may be "free" space. The fact that you started getting criticals after making the previous change leads me to think this might be the case. Try 10% and 5% for the thresholds, otherwise, you will have to use MB as uom.
sunnysthakur
Hi abrist.
I tried with %age but it always shows WARNING message on Nagios System or by command prompt.
I used lesser 10% and higher 90% but message is same.
Getting hint on google to use MB instead of %age as this plugin works well with MB only.
Now this is working fine.
Post by slansing »
Great thanks for letting us know, I am going to look further into this one.
