Nagios "background Image" missing
brianweeks22
Post by brianweeks22 »
Good Morning,
Weird Issue here..
I disabled nginx and enabled apache (My Preference)..
after doing that, all OF THE PAGES SEEM TO BE MISSING THEIR "BACKGROUND:.
Nagios Version 3.2.3
I attached a screenshot.. Im sure this is somethign simple, but I could not figure it out..
the screenshot attached show the tactical overview page
tHANKS!
Brian
NagHomePage.doc
(153.5 KiB) Downloaded 190 times
abrist
Red Shirt
Re: Nagios "background Image" missing
Post by abrist »
Looks like you are using the "Arana" frontend, is that correct? You may want to check your httpd error logs for some hints, post the output in code wraps:
tail -50 /var/log/httpd/error_log
brianweeks22
HAHA.. stupid me.. new directory with new install of apache! needed to transfer the files there.. seeing the log file helped!
THANK YOU!
Brian
abrist
Red Shirt
Post by abrist »
As always, you are most welcome. It is great when I tell someone to check the log files only to have them do so and fix the problem on their own.
Happy trails. This thread is locked.
