Hi ,
Is there an option to pull reports in CSV format ? We use pnp4nagios along with nagios to pull reports for hostgroups but the csv option is missing after we upgraded to 0.4x. Is there any way to restore this feature ?
Thanks in advance!
reports in csv format for Nagios 3.2.3
Re: reports in csv format for Nagios 3.2.3
Which exact version of pnp4nagios 0.4.x are you using? We of course always recommend only using what we include with the Nagios installation as this indicates said component has been tested and is valid.
