I have run the "Nagios XI Server" wizard on one XI server to monitor another XI instance (server A to server B) and I get the error "Error: Could not parse XML from https://nagios01/nagiosxi ()".
Doing the reverse (server B to server A) I get the same results. I have tested the passwords via the login page. What gives?
Zach.
problems with Nagios XI configuration wizard.
Re: problems with Nagios XI configuration wizard.
What is the exact address you are entering into the URL field of the wizard?
I found my own answer.
The wizard forms the url with :80 at the end even when the url begins with https://.
I edited the service command.
Is this the right place to submit a bug?
Zach.
Zach.
sreinhardt
- -fno-stack-protector
Interesting that it would do that. This would not be the correct place, please post to tracker.nagios.com, with the name of the plugin, version, and the information you found. Thank you for submitting this!
