This support forum board is for support questions relating to
Nagios XI, our flagship commercial network monitoring solution.
asmgiadmin
Post
by asmgiadmin »
Current perf graph isn't showing warning / critical levels:
host_name hostname.domain
service_description Disk Free Space - /dev/sda
check_command check_nrpe!check_disk! -a 90 99 /dev/sda
max_check_attempts 5
check_interval 2
retry_interval 1
notification_interval 60
contacts nagiosadmin
_xiwizard nrpe
register 1
How can I configure to display warning and critical threshold levels?
- Bugs find me
Post
by lmiltchev »
Can you show how the "check_disk" is defined on the client machine?
Be sure to check out our
Knowledgebase for helpful articles and solutions!
asmgiadmin
Post
by asmgiadmin »
command[check_disk]=/usr/lib64/nagios/plugins/check_disk $ARG1$ $ARG2$ $ARG3$
- Bugs find me
Post
by lmiltchev »
Change the the following line in the service definition on the XI server from this:
to this:
check_command check_nrpe!check_disk! -a '-w 10% -c 1% -p /dev/sda'
Note: Don't forget the "%" signs.
Hope this helps.
- Bugs find me
Post
by lmiltchev »
I'm glad I could help!
