check_ssh_login
debianite
check_ssh_login
Post by debianite »
Hi.
Is there such a plugin that can check if a user can login successfully to an ssh server?
Or maybe a script that will give exit status 0 if successful or 1 if not.
I'm asking this because I need to monitor an ssh server that authenticates trough ldap and some times the authentication stops working.
Any suggestions or ideas are greatly appreciated.
Thank you.
tonyyarusso
Re: check_ssh_login
Post by tonyyarusso »
Here's on that mmestnik wrote that you could try. I have no idea how it works myself, but in theory it should be capable of what you need.
check_ssh_expect.pl
(9.71 KiB) Downloaded 386 times
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
debianite
Re: check_ssh_login
Post by debianite »
Thank you very much!
That will give me something to work with. ;)
