I'm suddenly having trouble saving my configuration after adding hosts, editing and/or deleting services. Everything worked for weeks. Configurations failed to write to file.
All snapshots seem to be okay.
I have the following setup:
System:
Nagios XI Version : 2012R1.5
nagios.dc-******** 2.6.32-279.5.1.el6.x86_64 x86_64
CentOS release 6.3 (Final)
Gnome is not installed
Apache Information
PHP Version: 5.3.3
Agent: Mozilla/5.0 (Windows NT 5.2; rv:19.0) Gecko/20100101 Firefox/19.0
Server Name: 192.168.25.250
Server Address: 192.168.25.250
Server Port: 443
Date/Time
PHP Timezone: America/Chicago
PHP Time: Thu, 14 Mar 2013 06:49:04 -0500
System Time: Thu, 14 Mar 2013 12:49:04 +0100
Nagios XI Data
nagios (pid 19441) is running...
NPCD running (pid 1679).
ndo2db (pid 7369) is running...
CPU Load 15: 4.74
Total Hosts: 33
Total Services: 747
Function 'get_base_uri' returns: https://192.168.25.250/nagiosxi/
Function 'get_base_url' returns: https://192.168.25.250/nagiosxi/
Function 'get_backend_url(internal_call=false)' returns: https://192.168.25.250/nagiosxi/includes/components/profile/profile.php
Function 'get_backend_url(internal_call=true)' returns: https://localhost/nagiosxi/backend/
Ping Test localhost
Running:
/bin/ping -c 3 localhost 2>&1
PING localhost (127.0.0.1) 56(84) bytes of data.
From localhost (127.0.0.1) icmp_seq=1 Destination Host Prohibited
From localhost (127.0.0.1) icmp_seq=2 Destination Host Prohibited
From localhost (127.0.0.1) icmp_seq=3 Destination Host Prohibited
--- localhost ping statistics ---
3 packets transmitted, 0 received, +3 errors, 100% packet loss, time 2000ms
Test wget To locahost
WGET From URL: http://localhost/nagiosql/index.php
Running:
/usr/bin/wget http://localhost/nagiosql/index.php
--2013-03-14 12:49:07-- http://localhost/nagiosql/index.php
Resolving localhost... 127.0.0.1, ::1
Connecting to localhost|127.0.0.1|:80... connected.
Length: 5259 (5.1K) [text/html]
Saving to: `/tmp/nagiosql_index.tmp'
0K ..... 100% 325M=0s
2013-03-14 12:49:07 (325 MB/s) - `/tmp/nagiosql_index.tmp' saved [5259/5259]A tail -f of cmdsubsys.log shows that it hangs on
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosql/index.php --no-check-certificate --post-data 'Submit=Login&tfUsername=nagiosxi&tfPassword=io9750' -O nagiosql.loginLOGIN SUCCESSFUL!
URL: http://localhost/nagiosql/admin/verify.php
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/verify.php --no-check-certificate --post-data 'writeMonitoring=Go' -O nagiosql.export.monitoring
--2013-03-14 12:33:59-- http://localhost/nagiosql/admin/verify.php
HTTP request sent, awaiting response... tail: /usr/local/nagiosxi/var/cmdsubsys.log: file truncated
..........................................................tail: /usr/local/nagiosxi/var/cmdsubsys.log: file truncated
PROCESSED 0 COMMANDS
200 OK
Length: 4788 (4.7K) [text/html]
Saving to: `nagiosql.export.monitoring'
0K .... 100% 285M=0s
2013-03-14 12:35:32 (285 MB/s) - `nagiosql.export.monitoring' saved [4788/4788]
NAGIOSQL WRITE CONFIGS FAILED!\n
OUTPUT=NAGIOSQL WRITE CONFIGS FAILED!\n
RETURNCODE=5
What could be the problem?
Let me know if you need more info on this.
thanks
Christophe
