Error: Could not stat() command file '/var/nagios/rw/nagios.
amc_oldsarge
Post by amc_oldsarge »
I'm having a little trouble with Nagios starting up correcly.
Right after a reboot of my server, if I try to execute a manual service check I get:
Error: Could not stat() command file '/var/nagios/rw/nagios.cmd'!
But if I simply restart the nagios service, I can complete the manual service check without issue.
This happens after EVERY reboot. Now I could simply restart nagios after every reboot, but I'd really like to solve this permanently.
When I run: ls -al /var/nagios/rw
I get the following results:
drwxrwsrwx 2 nagios nagiocmd 4096 Mar 16 01:24 .
drwxrwxr-x 5 nagios nagios 4096 Mar 16 01:29 ..
After running: service nagios restart
Then running: ls -al /var/nagios/rw
drwxrwsrwx 2 nagios nagiocmd 4096 Mar 16 01:31 .
drwxrwxr-x 5 nagios nagios 4096 Mar 16 01:32 ..
srw-rw---- 1 nagios nagiocmd 0 Mar 16 01:31 live
prw-rw---- 1 nagios nagiocmd 0 Mar 16 01:32 nagios.cmd
after the nagios service restart nagios.cmd file shows up in the directory.
I following the instructions on this site:
http://nagios.manubulon.com/traduction/ ... dfile.html
I know this error is a common one and typically pertains to permissions, but I have tried reseting and even adding the nagiocmd group, but nothing has helped thus far.
Thanks for the assistance!
Re: Error: Could not stat() command file '/var/nagios/rw/nag
This is because nagios isn't running yet. The following files are created when nagios starts
