i have few questions on Dashboard Reports
1) can i remove reports of a particular Dashboards.
eg if i create a dashboard of Bandwidth details of particular port and i want to generate reports of that details
2) how can i generate the HOST Reboot report
3) Customizable Report : How can i create the customizable reports as per client requirement.
4) Live Dashboard to be created of report on 5 minutes
polling basis
Dashboard Reports
Re: Dashboard Reports
I think we might be mixing dashboards, dashlets, and reports
1) If you are talking about a dashlet (one piece of a dashboard) you can remove one by clicking the delete icon in the upper right of the dashlet
2) Not sure I know what you mean here, there is an availability report, under reports.
3) You can create custom components (which can be reports) following the guide here
http://library.nagios.com/library/produ ... evelopment
Or, if you would like to have Nagios Enterprises develop the custom report for you, you can contact [email protected] with a detail explanation of what is required and we can give you a quote for the cost to have the component developed.
4) All of the dashboards will automatically re-populate with the current data without refreshing the page.
rajthegladiator
Thanks for the reply....
1) i want to create a report of a particular Dashlet. how i do that.
2) Host Reboot : - If a Host gets rebooted automatically or if a host had an issue and it went down and it is made UP after sometime by the engineer.
can i get a host reeboot report of that particular Host , that how much time it took to come UP and can i get a lists of hosts that got rebooted.
4) How can we have a customizable Dashboards.....
1) You could create a new view, or find a page with the dashlet you are requiring a report of, and then click the "Schedule Page" button on near top right hand corner of each Nagios XI page. The icon looks like a miniature clock.
2) You could have Nagios XI report on the up time of that host in a number of ways, for example, you could set the Availability Report to one host, or an entire hostgroup, this would show you a number of graphics directed at what it sounds like you need.
3) We have a document which talks about exactly this: http://assets.nagios.com/downloads/nagi ... boards.pdf
