Monitoring CPU and Memery uses of Router/Switches
narendra.badgujar
Post by narendra.badgujar »
How to configure/Monitore CPU and Memery uses of Router/Switches.
Regards,
Narendra Badgujar
Re: Monitoring CPU and Memery uses of Router/Switches
This is going to depend on the actual equipment you are using you will either need to fin the correct SNMP oid and use the SNMP wizard, or you can find a plugin on the Exchange for your equipment and add it to Nagios XI
http://exchange.nagios.org/index.php?op ... o%20memory
http://library.nagios.com/library/produ ... -nagios-xi
