Is there a way to do a "Search and Replace" within NagiosXi?
For instance, if you have wanted to change the string on 100 service checks, contacts, etc...
Eddie
Search and Replace using NagiosXi
Re: Search and Replace using NagiosXi
This is not a current feature within Nagios XI. You can change certain options in bulk with the Bulk Modifications Tool, which is located in the following spot:
Core Configuration Manager > Tools > Bulk Modifications Tool. This option is available if you have purchased the Enterprise Edition of Nagios XI.
