HI guys,
Just wanted to warn everyone. Centos /RHEL has pushed version 1.4beta2 via yum . If you end up upgrading your package accidentally your system is going to be broken as it deletes the traphandler and changes permissions on all the snmptt folders.
If you end up doing it like without noticing (like mE!!!!!!!) , you will need to re-install the original nagios package and reset permissions on the folders. You might have a large number of un processed traps in the spool get rid of them.
Many Thanks
Arnab
SNMPTT and Yum updates
Re: SNMPTT and Yum updates
Thanks for the heads up. I just checked and you are correct. Given the number of XI users who regularly update their xi box, there will be more reports no doubt.
