Problem creating Nagios Admin user and password
devilsguest
Post by devilsguest »
Hi
I am new to nagios. Here is a weird problem that I am facing with nagios when creating nagios username and password using htpasswd -c command.As per my knowledge ./htaccess files are looking fine and have no problems. I am trying the command ./htpasswd -c /usr/local/nagios/etc/htpassword.users nagiosadmin which is throwing back error saying -bash: ./htpasswd: cannot execute binary file. Also, when i try to use the command as htpasswd -c /usr/local/nagios/etc/htpassword.users nagiosadmin throws me back error saying -bash: htpasswd: command not found. FYI I am running this command from /usr/local/apache2/bin. It would be great if someone can get me out of this problem that I am facing. BTW I am using linux server as my system.
Re: Problem creating Nagios Admin user and password
do not put the ./ before htpasswd
also usually the default for the file is /usr/local/nagios/etc/htpasswd.users
So
htpasswd -c /usr/local/nagios/etc/htpasswd.users nagiosadmin
devilsguest
You need the apache2-utils package to get htpasswd
devilsguest
I can see htpasswd with read write and execute permissions in my apache2/bin. So, What exactly am I suppose to do here? Do you think just the downloading apache2 util package will fix the issue?
devilsguest
I Also have apache2 util package in my system I do installed it with apache and configured too....
abrist
Red Shirt
Post by abrist »
Are you running the htpasswd command as root?
