Is it possible to have nagios use single sign in?
that is : once you login to nagios, you dont have to log into core or nagvis. This would be restricted by your security access level.
universal un and password
Proudly running:
Nagios Network Analyser
Nagios Fusion
Nagios Fusion
Re: universal un and password
We looked at this a few weeks ago, and unfortunately the answer is "no", at least without compromising XI's security.
screw security, I want ease of use darnit =D
thanks man you can lock it
Proudly running:
Nagios Fusion
Nagios Fusion
Just so you know, if you enable "auto-login" in XI, it will retain the username/password for nagvis, etc. But this is a *very* *bad* *practice*. Locking thread.
