Looking into it. It seems that the check_dns command uses $HOSTNAME$ and check_xi_service_dns uses $HOSTADRESS$
check_dns $USER1$/check_dns -H $HOSTNAME$ $ARG1$
check_xi_service_dns $USER1$/check_dns -H $HOSTADDRESS$ $ARG1$
The wizard used check_xi_service_dns and added '-a <ip>' as $ARG1$ (where <ip> is the ip address of the webserver).
This resulted in the command being fed the address and tried to compare the hostname to the IP Address resulting in a mismatch.
(something like found <hostname> expected <ip>)
I changed the service check to use check_dns since I really wanted it to use the hostname and look for the correct IP.
This part of the wizard appears to be what caused the mismatch:
case "dnsip":
$objs[]=array(
"type" => OBJECTTYPE_SERVICE,
"host_name" => $hostname,
"service_description" => gettext("DNS IP Match"),
"use" => "xiwizard_website_dnsip_service",
"check_command" => "check_xi_service_dns!-a ".$ip."",
"_xiwizard" => $wizard_name,
break;
