Timeperiod Management in new Core Config Manager
varnar
Post by varnar »
Hello All,
I found that small not comfortable option in new Core Config Manager when I try to change Time period.
In old, Legacy CCM, I was able to edit the day defined time period.
Please look at attached screenshots.
Re: Timeperiod Management in new Core Config Manager
Post by slansing »
You can manually enter the Definition, and then the time periods for that definition in the fields above the list. Then click Insert Definition and it will add the new time period, after which you can remove the old version, click save, and apply configuration.
abrist
Red Shirt
Post by abrist »
In the new ccm, you would just create a new definition and delete the old instead of modifying a current definition. Slightly different interfaces, same functionality.
varnar
Post by varnar »
abrist wrote:In the new ccm, you would just create a new definition and delete the old instead of modifying a current definition. Slightly different interfaces, same functionality.
Yes, I agree with that, but it will be nice to have that small future as well, because it make more fast to do some small changes.
Post by slansing »
Feel free to add a feature request on our tracker, be sure to note this thread's URL, the tracker is located at:
http://tracker.nagios.com/
