Nagios config error
hasselol
Nagios config error
Post by hasselol »
Hi! I got a problem i havent been able to solve after i reorganized my config files (It worked before i did it).
When i restart nagios:
ekonomi@ubuntu-it-lab:~$ service nagios restart
Running configuration check... CONFIG ERROR!  Restart aborted.  Check your Nagios configuration.
And then when i do config check:
ekonomi@ubuntu-it-lab:~$ sudo /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 3.4.4
Last Modified: 01-12-2013
License: GPL
Reading configuration data...
   Read main config file okay...
Processing object config file '/usr/local/nagios/etc/objects/commands.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/timeperiods.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/templates.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/hosts.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/services.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/dependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/hostgroups.cfg'...
Checking services...
        Checked 51 services.
Checking hosts...
        Checked 9 hosts.
Checking host groups...
        Checked 5 host groups.
Checking service groups...
        Checked 0 service groups.
Checking contacts...
        Checked 1 contacts.
Checking contact groups...
        Checked 1 contact groups.
Checking service escalations...
Checking service dependencies...
        Checked 0 service dependencies.
Checking host escalations...
        Checked 0 host escalations.
Checking host dependencies...
        Checked 1 host dependencies.
Checking commands...
        Checked 24 commands.
Checking time periods...
        Checked 5 time periods.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Checking misc settings...
Total Warnings: 0
Total Errors:   0
And when i use some sh command:
ekonomi@ubuntu-it-lab:~$ sh -x /etc/init.d/nagios start                         + test -f /etc/sysconfig/nagios
+ [ -f /etc/rc.d/init.d/functions ]
+ [ -f /etc/init.d/functions ]
+ prefix=/usr/local/nagios
+ exec_prefix=/usr/local/nagios
+ NagiosBin=/usr/local/nagios/bin/nagios
+ NagiosCfgFile=/usr/local/nagios/etc/nagios.cfg
+ NagiosStatusFile=/usr/local/nagios/var/status.dat
+ NagiosRetentionFile=/usr/local/nagios/var/retention.dat
+ NagiosCommandFile=/usr/local/nagios/var/rw/nagios.cmd
+ NagiosVarDir=/usr/local/nagios/var
+ NagiosRunFile=/usr/local/nagios/var/nagios.lock
+ NagiosLockDir=/var/lock/subsys
+ NagiosLockFile=nagios
+ NagiosCGIDir=/usr/local/nagios/sbin
+ NagiosUser=nagios
+ NagiosGroup=nagios
+ [ ! -f /usr/local/nagios/bin/nagios ]
+ [ ! -f /usr/local/nagios/etc/nagios.cfg ]
+ echo -n Starting nagios:
Starting nagios:+ /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
+ [ 126 -eq 0 ]
+ echo CONFIG ERROR!  Start aborted.  Check your Nagios configuration.
+ exit 1
Got any ideas?
Thanks in advance!
gshergill
Re: Nagios config error
Post by gshergill »
Hi hasselol,
Try running below:
sudo service nagios restart
Kind Regards,
Gary Shergill
hasselol
Post by hasselol »
Hi gshergill,
Yes i realized afterwards that i didn't have permission. Sudo did the trick.
Thanks alot!
Regards, Hasselol
Post by slansing »
Great, thanks for the help Gshergill!
