Sending e-mail from hostname localhost.localdomain?
cikoski
Post by cikoski »
My Nagios Xi when i try to send a test notification it works and it send me a mail with the correct hostname, but when the nagios send me a normal notification it send by the hostname localhost.localdomain and with this i can't recevie the notification...
Anyone can help me?
Re: Sending e-mail from hostname localhost.localdomain?
Post by slansing »
You should be able to set the "Send Mail From" address to something like...your local XI server. To change this navigate to Admin > Manage Email Settings and change the address.
cikoski
Post by cikoski »
slansing wrote:You should be able to set the "Send Mail From" address to something like...your local XI server. To change this navigate to Admin > Manage Email Settings and change the address.
Thanks for the speed of the reply!
I have resolve! Thank you very much!
