Scientific Linux, CENTOS
slothfatty
I'd suggest that instead of making it necessary to edit the install scripting to set up a trial version of XI on redhat clones, make the install more tolerant of otherwise identical operating systems.
Re: Scientific Linux, CENTOS
Thank you for the suggestions, I believe the installation is designed this way for the most part because of dependencies. Though they may be clones, some distributions have different structures "even on their minimal installations." Also, CENTOS and RHEL are the two most supported installations because they are two of the most upstream enterprise solutions. Though if you do have a feature you would like to see added such as an alteration to the installation script for better encompass other related distributions feel free to send it in as a feature request at:
http://tracker.nagios.com/
