Service Performance Data not showing for Nagios plugins
cybergene
Re: Service Performance Data not showing for Nagios plugins
Post by cybergene »
The perfdata files are located under :
/usr/local/pnp4nagios/var/perfdata
The OS information :
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION="Ubuntu 18.04.3 LTS"
Follow this procedure to reinstall Grafana.
It is written for Nagios Core. The other link you used earlier was for Nagios XI.
https://support.nagios.com/kb/article/n ... s-803.html
You should only have to start as the Install Grafana section as pnp4nagios is installed and seems to be collection the data.
cybergene
Post by cybergene »
@tgriep
Both pages are referring to https://grafana.com/docs/grafana/latest ... on/debian/ to install Grafana whether it is Nagios Core or Nagios XI, which I have done already.
I tried reinstalling and I think i'm good:
sudo apt-get install grafana
Reading package lists... Done
Building dependency tree
Reading state information... Done
grafana is already the newest version (6.5.2).
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
I restarted the services again and I'm still not getting any data graphed.
I had those couple error in the grafana.log
t=2020-01-09T17:04:04+0000 lvl=warn msg="Plugin missing module.js" logger=plugins name=PNP warning="Missing module.js, If you loaded this plugin from git, make sure to compile it." path=/var/lib/grafana/plugins/sni-pnp-datasource/dist/src/module.js
t=2020-01-09T17:04:04+0000 lvl=eror msg="Plugins: Failed to load plugin json file: /var/lib/grafana/plugins/sni-pnp-datasource/dist/src/plugin.json,  err: Failed to register plugin: Plugin with ID \"sni-pnp-datasource\" already exists"
t=2020-01-09T17:04:04+0000 lvl=warn msg="Some plugins failed to load" logger=plugins errors="[Failed to register plugin:\n    github.com/grafana/grafana/pkg/util/errutil.Wrap\n        /go/src/github.com/grafana/grafana/pkg/util/errutil/errors.go:18\n  - Plugin with ID \"sni-pnp-datasource\" already exists]"
Resolved them by doing this:
https://github.com/grafana/simple-json- ... fc58d9a694
and now the logs are clean but the graphs still don't have data.
Do I need to fix any config for pnp4nagios?
I would verify that the Grafana settings are pointing to the pnp4nagios performance datafiles.
I suspect that it is not as the files are in this folder
/usr/local/pnp4nagios/var/perfdata/
when Grafana might be looking in this folder for them.
/usr/local/nagios/share/perfdata
Another thing, can you login to the server with the pnp4nagios application and verify that the performance data is there?
cybergene
Post by cybergene »
installing the pnp4nagios components for Grafana on the sever is causing some errors, it seems to be missing a module.js
So I moved files around and now the logs are clean.
where in Grafana I can modify this? any specific config file?
/usr/local/nagios/share/perfdata/
Another thing; I got this message in Grafana query inspector
response:"<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd"> <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en"> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <title>Installation</title> <style type="text/css"> body { width: 42em; margin: 0 auto; font-family: sans-serif; font-size: 90%; } #tests table { border-collapse: collapse; width: 100%; } #tests table th, #tests table td { padding: 0.2em 0.4em; text-align: left; vertical-align: top; } #tests table th { width: 12em; font-weight: normal; font-size: 1.2em; } #tests table tr:nth-child(odd) { background: #eee; } #tests table td.pass { color: #191; } #tests table td.fail { color: #911; } #tests table td.warn { background: #ff3; } #tests #results { color: #fff; } #tests #results p { padding: 0.8em 0.4em; } #tests #results p.pass { background: #191; } #tests #results p.fail { background: #911; } #tests #results p.warn { background: #ff3; } </style> </head> <body> <h1>PNP4Nagios Environment Tests</h1> <p>The following options are determined by "configure". If any of the tests have failed, consult the <a href="http://docs.pnp4nagios.org/pnp-0.6/install">documentation</a> for more information on how to correct the problem.</p> <div id="tests"> <table cellspacing="0"> <tr> <th>PNP4Nagios Version</th> <td class="pass">pnp4nagios-0.6.26</td> </tr> <tr> <th>Prefix</th> <td class="pass">/usr/local/pnp4nagios</td> </tr> <tr> <th>Configure Arguments</th> <td class="pass">./configure '--with-perfdata-dir=/usr/local/nagios/share/perfdata' '--with-httpd-conf=/etc/apache2/sites-enabled'</td> </tr> <tr> <th>RRD Storage</th> <td class="pass">/usr/local/nagios/share/perfdata is readable.</td> </tr> <tr> <th>RRDtool Binary</th> <td class="pass">/usr/bin/rrdtool is executable by PHP</td> </tr> <tr> <th>PHP GD extension</th> <td class="pass">Pass</td> </tr> <tr> <th>PHP function proc_open()</th> <td class="pass">Pass</td> </tr> <tr> <th>PHP zlib extension</th> <td class="pass">Pass</td> </tr> <tr> <th>PHP session extension</th> <td class="pass">Pass</td> </tr> <tr> <th>PHP JSON extension</th> <td class="pass">Pass</td> </tr> <th>PHP magic_quotes_gpc</th> <td class="pass">Off</td> </tr> <th>PHP socket extension</th> <td class="pass">Pass</td> </tr> <th>Apache Rewrite Module</th> <td class="warn"><a href="http://docs.pnp4nagios.org/faq/i9">Apache mod_rewrite</a> is not enabled</td> </tr> </tr> </table> </div> <h1>Kohana Environment Tests</h1> <p>The following tests have been run to determine if Kohana will work in your environment. If any of the tests have failed, consult the <a href="http://docs.pnp4nagios.org/pnp-0.6/install">documentation</a> for more information on how to correct the problem.</p> <div id="tests"> <table cellspacing="0"> <tr> <th>PHP Version</th> <td class="pass">7.2.24-0ubuntu0.18.04.1</td> </tr> <tr> <th>System Directory</th> <td class="pass">/usr/local/pnp4nagios/lib/kohana/system/</td> </tr> <tr> <th>Application Directory</th> <td class="pass">/usr/local/pnp4nagios/share/application/</td> </tr> <tr> <th>Reflection Enabled</th> <td class="pass">Pass</td> </tr> <tr> <th>Iconv Extension Loaded</th> <td class="pass">Pass</td> <tr> </tr> <tr> <th>URI Determination</th> <td class="pass">Pass</td> </tr> </table> <div id="results"> <p class="pass">Your environment passed all requirements. Remove or rename the <code>/usr/local/pnp4nagios/share/install.php</code> file now.</p> </div> </div> </body> </html> "
I can point out that the following is the wrong location but I can't find the config file for that?
The data is located here:
Also, I replaced all the instances of
with
in all the files under this folder:
/usr/local/pnp4nagios/libexec/
-rwxr-xr-x 1 nagios nagios  8119 Jan  7 16:58 check_pnp_rrds.pl*
-rwxr-xr-x 1 nagios nagios 55045 Jan  9 19:50 process_perfdata.pl*
-rwxr-xr-x 1 nagios nagios 14988 Jan  7 16:58 rrd_convert.pl*
-rwxr-xr-x 1 nagios nagios  7855 Jan  7 16:58 rrd_modify.pl*
root@XXXXXXXX:/usr/local/pnp4nagios/libexec# vi
but the wrong folder location is still showing and the graphs are empty....
We currently do not have Grafana running so you should take a look at Grafana's site for configuration file locations.
Look here for more info.
Is says that the configuration file is here
/etc/grafana/grafana.ini
cybergene
Post by cybergene »
Yes, I figured that out, but there is nothing related to the perfdata files in there.
I have some good news though, I re-install pnp4nagios alone and now this:
If any of the tests have failed, consult the <a href="http://docs.pnp4nagios.org/pnp-0.6/install">documentation</a> for more information on how to correct the problem.</p> <div id="tests"> <table cellspacing="0"> <tr> <th>PNP4Nagios Version</th> <td class="pass">pnp4nagios-0.6.26</td> </tr> <tr> <th>Prefix</th> <td class="pass">/usr/local/pnp4nagios</td> </tr> <tr> <th>Configure Arguments</th> <td class="pass">./configure '--with-nagios-user=nagios' '--with-nagios-group=nagios'</td> </tr> <tr> <th>RRD Storage</th> <td class="pass">/usr/local/pnp4nagios/var/perfdata is readable.</td>
Looks better and it has the correct perfdata location:
Questions:
1-Any specific user to configure pnp4nagios with? as you can see above, I have nagios user in there, is that correct?
2- The timestamp on the perfdata files is changing but the sizes are not, why is that?
1. Nagios user is correct.
2. RRD files are round robin databases, as new data comes in, old is removed and they stay fixed in size.
https://en.wikipedia.org/wiki/RRDtool
cybergene
Post by cybergene »
I solved the problems with Grafana, it was pnp4nagios that had errors.
1. When I try to browse to http://nagios_ip/pnp4nagios/graph?host=hostname, I was getting
PNP4Nagios Version 0.6.26
Please check the documentation for information about the following error.
Call to undefined function simplexml_load_file()
file [line]:
application/models/data.php [270]:
and to solve, there was a thread about it in the forum:
https://support.nagios.com/forum/viewto ... =7&t=53095 and the solution is
sudo apt-get install php7.2-simplexml
sudo systemctl restart npcd.service
sudo systemctl restart apache2
2. Now, the 2nd error appeared:
sizeof(): Parameter must be an array or an object that implements Countable
file [line]:
application/models/data.php *[979]:*
Also from that same thread, to solve this error one need to fix the data.php model
go to /usr/local/pnp4nagios/share/application/models
sudo vi data.php
Replace it (in two places)
if(sizeof($pages) > 0 ){
with
if(is_arrary($pages) && sizeof($pages) > 0 ){
Source: https://github.com/lingej/pnp4nagios/issues/148
and restart apache2,
Test it by browsing to http://nagios_ip/pnp4nagios/graph?host=hostname, and the graphs should show up
If you try the Grafana visualizations , they will work.
Thank you for the help and you can close this thread ! :)
cybergene wrote:I solved the problems with Grafana, it was pnp4nagios that had errors.
file [line]:
file [line]:
sudo vi data.php
with
great!
Locking
