Config error for Exchange server and Network Switch
dmanem
Re: Config error for Exchange server and Network Switch
Post by dmanem »
The I/O wait seems to be fine. The first time I ran the configuration the I/O wait went up to 26% and the second time I ran it the max I/O wait was 12%. The rest of the parameters look good.
Out of curiosity, since we were able to successfully apply the configuration through the console, is the web interface still timeing out when applying configuration?
dmanem
Post by dmanem »
No, It is still timing out when I run the configuration wizard.
Can you verify that the cmdsubsys cron is running
ps aux|grep -v grep|grep cmdsubsys
dmanem
Post by dmanem »
It looks like they are running.
Thanks.
Not sure if these are related but looking over the list of file permissions you sent I did notice some anomolies and we should clean them up as well
rm -f nagiosql.*
chown nagios:nagios nagiosql_importall.php
Also, when you upped the time in your php.ini did you increase the available memory too?
dmanem
Post by dmanem »
I ran the commands and its still not working. When I increased the time I did increase the memory as well in the php file.
Thanks.
mguthrie
Post by mguthrie »
Have you added a large number of configuration items before Applying configuration? In other words, do you have a LOT (500+) of items in the Core Config Manager that do not appear to be synced to file?
What kind of results do you get when you use the Core Config Manager->Write Config Tool to export the configs?
dmanem
Post by dmanem »
No, all the hosts seem to be synced to file in CCM. When I run the write monitoring data in Nagios CCM it just gives a blank screen with Nagios Core Config manager on top. The rest of the write config tools work fine. The error when running the write monitoring tool is shown below. The time mentioned in the error mesage is 5 hrs past CST( the last message). Nagios and linux server are on CST. Could that be a reason it is timing out?
Thanks.
Please attach your system profile from
Admin -> System Profile
