CentOS errors
Re: CentOS errors
Yup this fix my problem ... but i dont know way this was happens or how in a first place. I have installed nagios many times and every time i follow the instructions from Installing nagios core ... so way this was happens ?
Re: CentOS errors
That is a mystery at this point since the resolution was simple and worked 100% of the time we did not dig deeper into the root cause, you may have changed time settings and restarted nagios while they were out of sync, or something may have goofed up in the retention.dat file "more likely." One question, what is the exact version of Core you are running? Another user is experiencing this however in his case removing and re adding does not work.
Re: CentOS errors
Time like change the time on the system ? Also im making snapshots on the virtual machine ( nagios is on virtual machine and making snapshots if i go wrong to go back, i do this often )? and this i dont understand goofed up in the retention.dat. Is this file is the same file from the downloaded tar.gz file that i just put it with "make install-init" and this error is code type in the same file, i put the code there i changed and worked or i put the correct file and it work. How can the code in the file be changed ? Any way it works now its okyou may have changed time settings and restarted nagios while they were out of sync, or something may have goofed up in the retention.dat file "more likely."
And for the questions Im running Nagios Core 4.0.1 on CentOS 6.4
Re: CentOS errors
This is hard to understand, I'm not sure what you are referring to here, but glad to see it is all resolved now.Is this file is the same file from the downloaded tar.gz file that i just put it with "make install-init" and this error is code type in the same file, i put the code there i changed and worked or i put the correct file and it work. How can the code in the file be changed ?
