Nagios and EMC Networker
brianweeks22
Post by brianweeks22 »
Good Morning,
DOes anyone knwo of a simple way to monitor EMC Networker backups with nagios (if a nightly backup fails.. need to insert new tapes into the tape library).. etc.. etc.?
any information would be greatly appreciated.
Thank You
Brian
abrist
Red Shirt
Re: Nagios and EMC Networker
Post by abrist »
Start by looking through the Exchange for plugins of interest:
http://exchange.nagios.org/index.php?op ... =networker
http://exchange.nagios.org/index.php?op ... chword=emc
If you want to do more than just alert, you will have to write some event handlers.
bosecorp
Post by bosecorp »
Any script that works for Networker 8
jdalrymple
Skynet Drone
Post by jdalrymple »
I don't see any that specify they work with version 8. You could go 1 of 2 routes:
1) Try it in your environment and see if it works. Very often major versions of software and hardware are still backwards compatible with Nagios plugins
2) Contact the authors of some of the plugins to see if they have advice regarding the newer version of Networker
This plugin is well documented and appears to do all you want: http://www.net17.de/projekte/nagios/index-e.html
bosecorp
Post by bosecorp »
I tried but only half of the features worked and other ones did not.
I will contact the author
jdalrymple
Skynet Drone
Cool - I'll lock this topic for now. PM me if you come up with anything and think we should unlock it.
