Unable to retrieve data from the local cache.
This support forum board is for questions relating to Nagios Fusion.
TBT
Post by TBT »
Upon adding a new Nagios XI server to Fusion, the error "Unable to retrieve data from the local cache." is returned.
Is this because no network element are being monitored yet, would localhost not be sufficient, any insight on this?
Nagios XI 2026R1.5 (8 Servers)
Nagios Fusion 2024R1.0.2
abrist
Red Shirt
Re: Unable to retrieve data from the local cache.
Post by abrist »
It may take some time before the local cache is first populated. Are you still experiencing the problem?
TBT
Post by TBT »
abrist wrote:It may take some time before the local cache is first populated. Are you still experiencing the problem?
Yes. Been over an hour. Please note nothing but localhost is being monitored on this new XI server.
sreinhardt
-fno-stack-protector
Post by sreinhardt »
If you go to Configure->Server credentials can you verify the following:
server type: Nagios XI
Authentication: Session
Check(far right): is green and OK
TBT
Post by TBT »
sreinhardt wrote:If you go to Configure->Server credentials can you verify the following:
Turned out to be an issue on my end (/etc/hosts)
Thanks for your time.
