Nagios and SNMP
dr5419
Nagios and SNMP
Post by dr5419 »
I have a nagios maching on my network that is monitoring my servers. I now need to use Nagios to accept and report SNMP traps. I have searched everywhere i know to search and have not found any articles on configureing Nagios to do this task. The hardware i am needing to monitor are Cisco 6509 Catalists.. the switches will send out SNMP messages but i can not figure out how to get Nagios to accept them. Any help is appreciated...
tonyyarusso
Re: Nagios and SNMP
Post by tonyyarusso »
There is a document on http://library.nagios.com/library/produ ... -nagios-xi that describes how to receive SNMP traps in Nagios XI, and the first two pages apply equally to Nagios Core. After that, you can analyze the source code of the wizard mentioned on page 3 to see the configuration format for creating a service to use them.
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
dr5419
Re: Nagios and SNMP
Post by dr5419 »
Thanks for your reply. I'm assuming by what i've read in the article you gave me that in order for this to work i will be needing to purchase and download Nagios XI? I am currently using Nagios 3.0.6.
tonyyarusso
Re: Nagios and SNMP
No, that's what I mean by "the first two pages apply equally to Nagios Core". The wizard stuff is only for XI, but the basic architecture applies to both - you just have to write your own configs manually.
Tony Yarusso
Technical Services
___
TIES
dr5419
Re: Nagios and SNMP
Post by dr5419 »
Thank you soooo much Tony.. I'll start going through the article now.. I really do appreciate it. Don
dr5419
Re: Nagios and SNMP
Post by dr5419 »
Ok. I guess i'm being dumb. I read through the link provided agove and am still having trouble. The link doesn't provde me instructions on pointing a switch thats sending the SNMP traps to the SNMP server and how to match the community strings. does anyone have any sample configs on how to do this? I am using Nagios3 with the SNMP plug-in. Thanks for any help given..
tonyyarusso
Re: Nagios and SNMP
I think this is all just done on the device end, and so you'd need to check the documentation for that. For instance, here's what it looks like for our Netgear switches:
I don't think there's any Nagios-end config about community strings when working with traps. Also, here's a config example for the service:
       host_name                       some-switch
       name                            snmptrap_service
       service_description             SNMP Traps
       max_check_attempts              1
       check_interval                  1
       retry_interval                  1
       notification_interval           1
       contacts                        nagiosadmin
       register                        1
       check_command                   check_dummy!0!"TRAP RESET"
       is_volatile                     1
       initial_state                   o
       active_checks_enabled           0
       passive_checks_enabled          1
       flap_detection_enabled          0
       stalking_options                o,w,u,c
       parallelize_check               1
       obsess_over_service             1
       check_freshness                 0
       event_handler_enabled           1
       process_perf_data               1
       retain_status_information       1
       retain_nonstatus_information    1
       notifications_enabled           1
       failure_prediction_enabled      1
Tony Yarusso
Technical Services
___
TIES
