What is the best syslog to use in combination with nagios core.
I want to log cisco devices and with a trigger at them to nagios for monitoring.
Just a question??
sreinhardt
- -fno-stack-protector
Re: Just a question??
Depending on what you are looking to do snmp or snmptraps might be a better alternative. Otherwise we do not really have a "suggested" syslog server but there appears to be a few articles on syslog-ng.
I want to log my cisco devices and event logs of my windows machine and then with triggers at them in nagios, That when a certain event is in the eventlog that nagios will alert me.
sreinhardt
With windows, you should look at nsclient most likely. For cisco, syslog-ng again is probably the best. However in both cases, unless you are running server 2012, snmp traps and gets will provide most everything that monitoring logs can in a fairly easy format.
