Attached pdf was the observation we found when we checked branch post re-configuring the polling interval to 1 min.the router was rebooted. Even then the router availability for that particular time shows 100%. Attached the report. Router was rebooted at 5:36 PM and came up by 5:38 PM, but the availability is 100% up.
pls clarify.
Router Availabilty | Polling Interaval issue
wiproltdwiv
Re: Router Availabilty | Polling Interaval issue
How many retries are configured for this host check? Could it have been responding to pings before it was fully up?
wiproltdwiv
recheck interval is 1 min and check attempts is 5 min ...
no its not responding to pings before it was up..
If the check attempts are set to five attempts at 1 min each, and if the downtime was less than 5minutes (which it was as it was only down for 2 minutes), then the check never reported a HARD problem state as it recovered after a maximum of two SOFT failures. That is why your uptime is still reported at 100%.
