Hi All,
I am new to nagios, we did a fresh install of nagios core (v3.2.3) and every time nagios server is restarted, its replacing the existing snmpd.conf file, and so custom entries added manually in that file are getting lost. Please help!
Regards
Verditer
Nagios replacing SNMPD Configuration File
sreinhardt
- -fno-stack-protector
Re: Nagios replacing SNMPD Configuration File
Is this a packaged version of nagios? At no point in time, should nagios overwrite or interact directly with the snmp configuration files. Can you provide a before and after of the altered file? Also do you use puppet or any other centralized configuration management that may be doing this?
