Virtual PC, 32-bit.
Was using Internet Explorer 9, 32-bit. Now using Opera.
Not sure where I should place this topic but I guess it can be moved once posted or reviewed by a mod.
Just upgraded to the latest build. No major jump just one step up.
Went to add one of our technicians to a specific host via Alert Settings. Found that Assigned was completely blank and I could not add anyone. This was the same for both contacts and contact groups. The same for hosts and services as well.
Odd instance was odd.
I was using Internet Explorer 9 at the time and never really have a problem with it (aside from the occasional crash
My compatibility was on, so turned it off. Same issue. No smartscreen, no pop-up blocker, standard stuff really.
Let me know if you have any questions! Will try a few things here and there throughout the day.
Maybe the forum can figure this out, no rush though.
Thanks for time and efforts as always,
waydms
