Hendrik BŠäcker wrote:
> Hi List,
> since memory eating ePN is enabled as default in Nagios 3 some users ran
> into fork error cause of memory limits, but no one told them.
> They only see some log messages like: "Warning: The check of service xx
> could not be performed due to a fork() error."
> I've spent some time on the code and would suggest attached patch.
> Since the "fork_error" is only filled once in
> "run_async_service_check()", I guess it should be ok to move the logging
> earlier up to the fork error, so we could use strerror() to determine
> why the error occurs.
> But I am not sure if the part:
> if (fork_error == TRUE)
> return ERROR;
> has to stand at the last lines of the function or if we are able to
> return quiet after the fork error.
> It would be nice to see s.th. like sterror() in checks.c so that the
> users out there could imagine why an fork error occurs.
> Regards,
> Hendrik
Good idea Hendrik - I'll get this applied to host check fork() errors as
well. Thanks again.
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
