IBM-AIX Monitoring
shabeer
IBM-AIX Monitoring
Post by shabeer »
How to monitor IBM-AIX machine in NagiosXI?
is it possible to use snmp for monitoring ibm-aix machines?
pls give me step by step instaruction to proceed....
Shabeer
tonyyarusso
Re: IBM-AIX Monitoring
Post by tonyyarusso »
Yes, SNMP would likely be the easiest route. There is a configuration wizard available for SNMP (http://exchange.nagios.org/directory/Ad ... rd/details), so you can just walk through that for whatever OIDs you want to monitor. If you need any additional MIBs specific to AIX there is a document on SNMP integration on the Library that includes a section on that, but most things should be pretty standard.
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
