We are having problems now with unknown alarm signal.
For example
***** Nagios *****
Notification Type: PROBLEM
Service: CRON
Host: linux - test
Address: 1.1.1.1
State: UNKNOWN
Date/Time: Mon Feb 21 13:13:06 CET 2011
Additional Info:
ERROR: Alarm signal (Nagios time-out)
This is check_snmp_process module, version 1.10
http://nagios.manubulon.com
Could you please help finding the problem?
regards,
Mariusz
Nagios time-out
tonyyarusso
Re: Nagios time-out
Could you try running the check command directly from the shell (as the nagios user, with all the appropriate arguments)? Does it succeed? How long does it take?
