Hash: SHA1
Marc DeTrano schrieb:
> I believe I found a bug in commands.c, in : disable_service_notifications
> (around line 3540 or so in HEAD).
> The call to broker_adaptive_service_data comes before the switch to
> svc->notifications_enabled=FALSE.
> In enable_service_notifications, enable_host_notifications, and
> disable_host_notifications, the switch always comes before the broker is
> called. This means if you are trying to catch the disabling of
> service notifications in a broker module (as I am doing), you have no
> way to inspect the value of "notifications_enabled" to determine if this
> was just enabled or disabled.
Did you patched your nagios code to move the switch case before?
Is nagios doing it's job as before?
If so - please send a unified diff to this list. We will review and test
it. If it won't break s.th. else we will queue it for the developers to
upstream.
> Hope this helps, and thanks for all the great work on Nagios.
A patchfile should help more than thousand words
Hendrik
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.8 (Darwin)
iEYEARECAAYFAkjy0WwACgkQlI0PwfxLQjnn0QCfaBUtYxn9dM59ycZtumuuVr1y
6UMAnRrEt1v2PSYuH7VIj+660RZb4H/I
=FLsg
-----END PGP SIGNATURE-----
