Hello Guys,
Can anyone help me about the error below ?
I have tried to find a solution, but I didn't.
[root@localhost nagiosxi]# ./E-importnagiosql
NOTE: If prompted, enter the MySQL root password
NagiosQL database appears OK - continuing...
NDOUtils database appears OK - continuing...
ERROR: No files to import - exiting. Were Nagios Core and NagiosQL installed?
thank you.
Cheers,
Hugo
NagiosXI - E-importnagiosql
Re: NagiosXI - E-importnagiosql
Hello Hugo,
by chance is this being installed on RHEL, and if so, is it registered?
If possible, could you look through the logs and see where it may have failed? It sound like something didn't go correctly in ./1-prereqs
I am having the same problem.
I think it may be an issue with a proxy.
It seems the 1-Prereqs does not install all of the conf files for Nagios Core.
Once I copied them from the vmware install I then get a error asking if I we have a proxy.
We do have a proxy, it seems the wget for the local host is hitting a proxy and failing.
I will test this today using a host file to see if it makes a difference
Tstahl
I am going to follow up on this in the other thread we have going so as to keep it focused in there and you are using CentOS.
http://support.nagios.com/forum/viewtop ... f=6&t=2186
Thank you.
Thank you.
