Set up monitoring of an exhange server using the Monitoring Wizard for Exchange, it's a 2010 Exchange server. We selected OWA HTTPS and we get the following error:
HTTP/1.1 500 Internal Server Error
Service command is:
check_xi_service_http! -H svr*****01.hhsc.org -f ok -I XX.X.XXX.XX -u "/exchange/" -S
The Exchange Server Admin is asking:
"Do you know how it checks OWA HTTPS? Does it use an account to connect?"
We're also getting a warning on HTTP OWA:
HTTP/1.1 403 Forbidden
But we're not too worried about that one right now. Everything else is being monitored properly.
Mahalo;
Charles
Exchange OWA HTTPS Error
Charles Masteller
Information Systems Specialist
Hawaii Health Systems Corp.
"No one will ever need more than 640K RAM". Bill Gates
Re: Exchange OWA HTTPS Error
Perhaps if I answer the questions your admin was asking, that might help solve them:
1) It uses check_http plugin, which attempts to connect to the given host and the given path using the given port. It can use a username/password, however our check does not. I looked at our wizard and it can use a password on the backend, but its not programming into the frontend. Would this be causing 500s for your https? Are you using a nonstandard port for https?
Nicholas Scott
