monitor Windows Process handles via nagios
paul559
Post by paul559 »
Hello all,
I am very new to nagios.
I have a custom service on Windows 2008 servers that i would like to monitor the handles with nagios. Sometimes the handle grows so much that we end up restarting the service (developers are working for a fix).
Is there a way?
see attachment for exactly what i am talking about.
Thank you,
Paul Walia
windows handles.docx
(19.7 KiB) Downloaded 377 times
Re: monitor Windows Process handles via nagios
Post by slansing »
Do you mean you want to monitor the process that is spawned when opening a command prompt? Other than that I do not see a example of your custom service.
paul559
Post by paul559 »
slansing wrote:Do you mean you want to monitor the process that is spawned when opening a command prompt? Other than that I do not see a example of your custom service.
Thank you for your quick reply. Let me give you exact example in the attachment.
If you see there are multiple instances of this qp_rept_scheduler.exe process. Right now Handles look normal but 2 days ago one of the service handles were up to 12 million and it died on us. I want to monitor these handles for this services.
qp service.docx
(27.49 KiB) Downloaded 357 times
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Do you have a specific way you would like to monitor this, wmi, snmp, or agents? I would be quite surprised if there was a current way with snmp, but wmi would likely have this information available without an agent, and via ncpa or another agent this is absolutely possible, as you could use a scripted solution to inform you.
mickem
Post by mickem »
This is supported in NSClient++ 0.4.2
// Michael Medin
// Michael Medin @mickem, blog.medin.name
Author of NSClient++ - http://nsclient.org
NSClient++ 0.4.2 Documentation: http://docs.nsclient.org
sreinhardt
Cool, nice to know! Thanks Michael!
abrist
Red Shirt
Post by abrist »
mickem wrote:This is supported in NSClient++ 0.4.2
What would be the syntax for such a check?
mickem
Post by mickem »
First off 0.4.2 is currently out as beta.
A RC will be out in the coming weeks and a release a bit after that once people have reported back all bugs.
The documentation for 0.4.2. can be found here: http://docs.nsclient.org
But some better docs (usage oriented) can be found on the blog: http://www.nsclient.org/nscp/blog (these will be merged with docs eventually).
A relevant (sort of) example from the blog post is:
check_process process=explorer.exe "warn=working_set > 70m" "detail-syntax=${exe} ws:${working_set}, handles: ${handles}, user time:${user}s"
explorer.exe ws:77271040, handles: 800, user time:107s
Performance data: 'explorer.exe ws_size'=73M;70;0
Where we actually check memory but show handles.
What you want is to replace the check to also check handles like so (I also added in a critical threshold for fun):
check_process process=explorer.exe "warn=handles > 70" "crit=handles > 700" "detail-syntax=${exe} handles: ${handles}"
L     client CRITICAL: explorer.exe handles: 1256
L     client  Performance data: 'explorer.exe handle count'=1256;70;700
// Michael Medin
abrist
Red Shirt
Post by abrist »
OP: Lets us know how the check configuration treats you.
guigigena
Post by guigigena »
I had the same issue, i found a simple way to do this.. With the agent NSCP++ and the module CheckCounter...
CheckCounter "Counter:Handle=\\Process(Explorer)\\Handle Count" ShowAll MaxWarn=2000 MaxCrit=10000
Any conter of the perfmon can be added to the checkCounter, to know the name of the counter open the permon, add your counter, then select the same and go to properties to see the path.
Ex: \Processor(_Total)\%Idle Time
With CheckCounter add a \ more and the warn and Critical values
CheckCounter "Counter:Handle=\\Processor(_Total)\\%Idle Time" ShowAll MaxWarn=2000 MaxCrit=10000
I Hope this help someone...
