im trying to go to my nagiosxi webpage, but when i do 192.168.130.50/nagiosxi i only see a blank page nothing else.
If i do 192.168.130.50 i get :
"welcome to nagios" then i click on "Access Nagios XI"
I get the blank page
Help please
URL is Blank
afernandez
Re: URL is Blank
ok i see something on the logs:
Can't connect to MySQL server ip addres of database
how do i troubleshoot this?
please?
please?
afernandez
Re: URL is Blank
we bought license i dont have permission to post in customer forums
afernandez
Re: URL is Blank
Fter fixing the mysql connection problem still i can not acces the nagios url and i can see in the nagiosxi server logs that the monitoring is going on is just the url that dont work
help please
help please
afernandez
Re: URL is Blank
I am sorry here are the details you request for a prompt resolutiuon i apologize i didnt read the guide lines, if there is anything else you need , just let me knowFor all support requests, we need to know:
What version of Nagios XI are you using? 2012r2.5-1
Linux Distribution and version? Centos release 6.4 (final)
32 or 64bit? 64 bit
VMware Image or Manual Install of XI? VMware Image
Are there special configurations on your system, ie; is Gnome installed? Are you using a proxy? Are you using SSL? there is a proxy
32 or 64bit? 64 bit
Re: URL is Blank
Just a note: Do not bump your own posts as we try to answer threads based on age, with the oldest first. Bumping will delay our response to you. You are welcome to edit your last post in a thread to update it will more information though.
Lets start with the server logs:
tail -25 /var/log/httpd/error_logFormer Nagios employee
afernandez
Re: URL is Blank
I think there is something wrong with that paste site:
Software error:
Global symbol "$ip" requires explicit package name at lib//Paste.pm line 242.
Compilation failed in require at /var/www/vhosts/paste.debian.net/paste.pl line 28.
BEGIN failed--compilation aborted at /var/www/vhosts/paste.debian.net/paste.pl line 28.
Re: URL is Blank
Looks like that URL is having some internal server problems. Can you post the log to pastebin or something else? Be sure as always to edit out sensitive information.
