Operations Center not displaying information.
This support forum board is for questions relating to Nagios Fusion.
TBT
Post by TBT »
In Fusion 2012R1.6, both Tactical Overview and Tactical Summary are displaying information, but Operations Center is empty.
Nagios XI 2024R2.2.1 (8 Servers)
Nagios Fusion 2024R1.0.2
Re: Operations Center not displaying information.
Post by slansing »
Can you access the Ops Center and then run:
tail -25 /var/log/httpd/error_log
Then share the output here. Thanks!
TBT
Post by TBT »
[Sun Oct 27 03:13:05 2013] [notice] Digest: generating secret for digest authentication ...
[Sun Oct 27 03:13:05 2013] [notice] Digest: done
[Sun Oct 27 03:13:06 2013] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.0-fips configured -- resuming normal operations
[Mon Oct 28 10:03:19 2013] [error] [client 10.2.26.252] PHP Notice:  Undefined index: user_id in /usr/local/nagiosfusion/html/includes/utils-dashboards.inc.php on line 14
[Mon Oct 28 10:04:03 2013] [error] [client 10.2.26.252] PHP Notice:  Undefined index: user_id in /usr/local/nagiosfusion/html/includes/utils-dashboards.inc.php on line 14, referer: https://domain.com/Nagios+Guidelines+and+Documentation
[Mon Oct 28 10:21:32 2013] [error] [client 10.2.1.34] PHP Notice:  Undefined index: user_id in /usr/local/nagiosfusion/html/includes/utils-dashboards.inc.php on line 14
[Mon Oct 28 10:29:30 2013] [error] [client 10.2.1.34] PHP Notice:  Undefined index: user_id in /usr/local/nagiosfusion/html/includes/utils-dashboards.inc.php on line 14
[Mon Oct 28 10:40:01 2013] [error] [client 10.2.26.252] PHP Notice:  Undefined index: user_id in /usr/local/nagiosfusion/html/includes/utils-dashboards.inc.php on line 14
[Mon Oct 28 11:29:50 2013] [error] [client 10.2.26.251] PHP Notice:  Undefined index: user_id in /usr/local/nagiosfusion/html/includes/utils-dashboards.inc.php on line 14
[Mon Oct 28 11:31:27 2013] [error] [client 10.2.26.252] PHP Warning:  file_put_contents(/usr/local/nagiosfusion/tmp/fusion_components_api_versions.xml): failed to open stream: Permission denied in /usr/local/nagiosfusion/html/admin/components.php on line 573, referer: https://domain.com/nagiosfusion/admin/components.php
[Mon Oct 28 11:31:44 2013] [error] [client 10.2.26.252] PHP Warning:  file_put_contents(/usr/local/nagiosfusion/tmp/fusion_dashlets_api_versions.xml): failed to open stream: Permission denied in /usr/local/nagiosfusion/html/admin/dashlets.php on line 440, referer: https://domain.com/nagiosfusion/admin/dashlets.php
Post by slansing »
What user are you logged in as? If it is not the nagiosadmin, what rights does it have?
TBT
Post by TBT »
slansing wrote:What user are you logged in as? If it is not the nagiosadmin, what rights does it have?
Logged in as my user, with Fusion authorization level Admin.
Did you just install the component? It takes a while before the data gets populated.
TBT
Post by TBT »
lmiltchev wrote:Did you just install the component? It takes a while before the data gets populated.
No. Nothing has been installed since we upgraded to 2012R1.6 few days after it was released.
Go to: Admin->Manage Components and see what is the version number of the Operations Center component. Mine is 1.1 and I am not having any issues.
You may also try removing the component and reinstalling it (Admin->Manage Components->...->Browse->Upload Component). You can download the latest component from the Nagios Exchange:
http://exchange.nagios.org/directory/Ad ... nt/details
TBT
Post by TBT »
- Version 1.1
- Your suggestion produced the same result
- I also noticed the following Dashlets display no information: Open Problem Summary, Open Host Problems, Open Service Problems
I am not able to reproduce the issue in house. Can you view the info if you log in as a different user (nagiosadmin, etc.)? Is SELinux disabled?
