I was able to get the map to work, but it doesn't appear to be showing any hosts connected to the main server.
How do I add the other two machines I am monitoring to the map? Can i customize what image is used to represent them? Thanks for any help.
However, if I select a different view mode, they show up. They don't have any parent's associated with them though. How do I specify the main Nagios server as the parent of the two servers running NRPE?
